I need to get an axle with the cairer to replace the long axle on the left side I need to no witch car will it work from and the year thanks for the info
:smokin:
:smokin:
FUN IN THE SUN IN MY LXI BOLINKXR
b20a dc header, cat back ,tokico springs, mugen intake ,full msd vortec fuel pressure regulator, sei disk brakes, 16" rims reverse indiglo gages, 4wS pralude stering wheel
Try the 90-93 Integra Axles.
'88 LX-i Coupe --- LS/Vtec
if you still have the original engine (A20AX) you can't use equal length axles from a B20 or any other engine. There is no place to bolt the intermediate shaft to the engine.
I dont under stand what you mean .will the 90-93 axle work and will the cairer baring on the shaft bolt in place where the oniginal one was mounted .the one that came on the engine was damaged when i got![]()
oh! you mean that you tant to replace the intermediate shaft on your B20!! I thought that you wanted to get an intermediate shaft on an A20A.. sorry
Now, for your problem, I just don't know the answer.
So, did you find out what kind of axle you need?
