Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: Anyone Have A Stage 2,3,4,5 Clutch In Their Accord?
    SEi User johndej's Avatar
    1989 Accord LX-i 5 speed hatchback
    Culpeper, Va.- home, JMU (Harrisonburg, Va.)- school
    did i hear stage 2?!?! sorry, got in on the end of this tread. yeah, from what everyone is saying all you have to do is get the stage 2, don't drive the hell out of it (thats not good for anything), and give it a proper break in. does that work?
    "Eat, Drink, and be Merry!"
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    yes
    10 sec 87 honda accord Lx-i
    Hamden,Ct
    I use a 4 puck solid hub for my car and have not yet broke a tranny with hd plate from ACT.
    89' LX-i Accord
    Miami
    I riped my tranny to pieces when i put my stage 2 clutch in, but i ran it hard. They are right my motor mounts were fryed in about two months. The front one was so bad that it came aoart in 2 pieces! Don't abuse it and it will be ok.
    Short Ram Intake.
    Pacesetter Catback.
    MSD coil.
    ACT Stage 2 Clutch.
    Custom Short shifter.
    Drop Zone Coil Overs.
    20% Tints.
    Pioneer DEH4400.
    Pioneer 3 ways.
    RF Amp, 12" HX2.
    Feb 2003
    89 accord lxi
    williamsburg va.
    to address the statement a clutch dosent give you more power . It will not give you any more power at the flywheel , but since the average drivetrain consumes 15% of the power between the wheels and flywheel , since the new clutch is more efficient at holding that horsepower shouldnt you then gain more at the wheels . Probably nominaly , but it makes sense to me
    p
    accord HB ( metallic green)
    B.C Chilliwack
    I put my centerforce dual friction in about 2 months ago, and it is great. BUT damit, now my synchros in my tranny are going. Really bites, anyone rebuild one of this trannys at home, and is there any upgrades we can do to it ?
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    Re: Anyone Have A Stage 2,3,4,5 Clutch In Their Accord?
    UPDATE
    wanted to add some current info to this thread, this issue is still coming up from time to time. another point you want to look at,if you add a stiff clutch, the shock of it engaging over and over,will eventually wear on the thrust surfaces of your crankshaft, every time the clutch engages,the shock will transfer through the crank,which will put load on the thrust washers,wearing them. the entire crank wants to walk forward in the block. If you get a clutch upgrade,go to a centrificial clutch, this engages easy and holds by a different method other then stiff springs in the clutch plate. also a stiff clutch is hard on the clutch cable. make sure if you upgrade,that your dog bone is in decent shape,this keeps the motor from rocking backwards, this is the most common reason the front and rear motor mounts fail. they have a motion range they are designed for, without that dog bone damping the motion,they get overextended.
  8. #33
    LX User bank2me's Avatar
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Who makes the centrifical clutches that wont ruin anything?
  9. #34
    SEi User
    Jan 2004
    Hmmm interesting i've not really had too much of an issue with the thrust washers wearing out?? but will keep an eye on it, luckily when i had the bottom of the block out i did have some play but as it had done 15k race miles and before when i rebuilt it i didn't have anyspare so i just used the best 2nd hand ones that i had which probably didn't help!! lol!! I pulled the engine a while ago and put it back in with the new ones in their is no play in the crank anymore. As with the trannies blowing could be any number of reasons if they allready had a fair amount of mileage on them. I've got a completely rebuilt teg tranny with uprated bearings and new syncros seems to be fine and yes upgrading the dog bone is a very good idea i just added duck tape to the rubber bush and bashed it back into the dogbone, now stiff as poly and next to no movement on the engine :O)
  10. #35
    I was told i have a stage 2 in my car. I think its a stage 1(recepets). But it grabs fine, quick when needed, and slips. DO NOT PUT A STAGE 3 UNLESS YOUR TURBO AND PUSH HIGH HP!!! I drove a stealth with a stage 3 clutch and it was hell. so stiff and it grabbed so damn fast.
  11. #36
    Jul 2008
    1989 LX Coupe 5 speed
    Rothesay
    Talking Re: Anyone Have A Stage 2,3,4,5 Clutch In Their Accord?
    I almost bought a 1991 Dodge Stealth [automatic] with 274 HP before i bought my Accord, and from the problems Stealth's have, im glad i made the right choice. Woot 3Geez
    89 LX Coupe - 5 speed
  12. #37
    i have a stage 3 pressure plate and its fine...so far i think my car only makes like 120whp. yes i do stall it sometimes but its because i got to rev it a lil bit to get it going
    ^^ just a stage 3 pressure plate? wut stage clutch then??? lol i wouldnt want a stiff pressure plate... it would suck.
  14. #39
    the clutch disk is a stage 2 sprung Kevlar disk
  1. Best Stage 2 Clutch?
    By mushroom_toy in forum Performance
    Last Post: 04-03-2010, 12:17 AM
  2. Stage 3 clutch!
    By itzdave in forum Performance
    Last Post: 03-26-2009, 11:28 AM
  3. stage 1 clutch from Clutch Master or Nippon
    By MarioBurke in forum Performance
    Last Post: 07-11-2003, 11:25 PM
  4. clutch masters STAGE 3
    By 87 Honda Prelude in forum Performance
    Last Post: 08-27-2002, 05:21 PM
