Hey guys wondering if anyone can give me some advice, I've owned this 89 Accord LX for years and I love the car but after running perfectly fine for the better part of a year, it just suddenly started to give me problems after I drove it to work, shut it off, came back and cranked it to find this newly developed problem.. don't you just hate that?
Anyways, it's drivable I've driven it for 5 days with this problem, all I really do is give it extra gas to keep it from stalling out, if I know I'm coming to a stop I throw it in N and pump the gas lightly I drive standard too, so working gas pedal and brake pedal in this fashion isn't hard for me although this car is an Auto tranny.
It has a real rough idle, in N will stutter and put struggling to stay alive. I avoid coming to complete or almost complete stops while in gear. A couple years ago I had a flooding problem and found a mechanic out of state who knew Honda Carbs, he did a minor rebuild and the problem was float related. If it does stall it cranks right back up and I just have to give it extra gas. I'm just happy the fast idle still works in the morning, because its getting colder here and that functionality is mucho important. Once it drops to what its supposed to be in regular idle though, it will stall if I let it, Neutral has become my best friend with this issue, I've checked vacuum lines and bought some new NGK plugs and some new wires that I'll be replacing soon just to rule out a possible misfiring cylinder.
If its carb related again.. I wonder if there's anything I can do to raise the idle? I drive 3-4 miles on bumpy roads. I know there are several screws on the carb, I definitely don't want to change the fast idle settings which I believe are on the passenger side of the carb by the fast idle cam. It seems to be running lean it used to run too rich (flooding) I'd love to take it to that mechanic again because he knows which screws to tinker with and which vacuum lines to unplug/plug up when doing a quick rig adjustment he's just far away from my home and busy I'd want to call him and make an appointment for him to have at least an hour to check it out but its a little inconvenient at the moment. Plus he doesn't like messing with them anymore I can tell although he has helped me out. Also could my PCV valve be bad?
Edit: Car has 126k original miles, replaced fuel pump twice in the past 40k miles as well as fuel filter. Only run with Non-Ethanol Gas since over a year ago.
