My passenger window will go down, not up. I need to get it up to buy time to actually fix it and it's going to rain. Can I take advantage of the down function working and jumper it to go up instead? Thanks.
I just found w261w261's post, "Try this: with the window down and power off, unplug both plugs from the controller. On the 6 wire plug, jump between the black/yellow wire (should be hot with ignition on and the window switch pushed to up position), and the red/yellow wire on the 4-connector plug (to the motor-up) . On the 4 connector plug, jump between the red/blue wire (return from motor) and the black wire on the 6-connector plug (to ground). Turn on the car's juice, and hit the window up switch. If the window goes up, the problem is the controller."
If this is my problem I wonder if new controllers are available.
