Results 1 to 11 of 11
Thread: new to the site
    Dec 2014
    1989 honda accord lxi hatch
    joplin mo
    new to the site
    hey, new to the site. names jason with a 89 lxi hatch. WITH PROBLEMS
    Re: new to the site
    LOL. Welcome!
    LXi User RAZR's Avatar
    May 2010
    1986 accord LXI
    Chicago Il
    Re: new to the site
    Welcome!!
    Explain some of these problems!
    Jul 2009
    Somerville, Alabama
    Re: new to the site
    Hi Jason. My Heavy Rescue we run came from Joplin Missouri. Welcome to the site!
    Shaggy
    FF II/ETC I
    Dec 2014
    joplin mo
    Re: new to the site
    bought the car for 600. towed it from springfield to joplin. put a new battery in it and it fired right up. long story short. it was leaking coolant, and oil really bad. the coolant pipe that goes into the water pipe was corroded bad. so i decided to do a full gasket reseal and tune up. go the head reworked with new valves. car ran fine for maybe a week. would have problems starting. and misfiring. cylinder 4 is dead misfire right now. has spark and fuel, compression is great. found coolant sensor wires broken at the connector. replaced connectors and sensors. went to the salvage yard for the connectors. the car is at a honda shop, not a dealership. they can't figure it out. if you take cylinder 4 plug out its soaked in fuel. INJECTORS ARE NEW! dry the plug off put it back in, car runs good for maybe a minute then starts the dead misfire again. the honda guy put the new coolant sensors in with the connectors and the car ran good for a minute then back to misfiring. he said if you push the diapham in the egr up manually while running it should stall the engine. it doesn't, it actually speeds up......im bumbed and fustrated. any suggestions would be awesome! i have used the search so....ya
    Jul 2009
    Somerville, Alabama
    Re: new to the site
    Try another injector on cylinder 4. better yet, swap cyl 3 and 4 injectors out and see if the misfire moves to cyl 3. I'm willing to bet you have an issue with your injector somewhat along the lines of dirt/nastyness causing it to stick open longer than it should or stuck open even better. Sounds somewhat like your cylinder itself is flooding.
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    Re: new to the site
    If you have to buy an injector, i think the company is called Airtex or somewhat along those lines. Around $25/ea. You'll have to get it online for those prices. O'Reillys stocks them for $80/ea with their steep price markups and all
    Shaggy
    FF II/ETC I
    Dec 2014
    joplin mo
    Re: new to the site
    thats what i was pondering on! thanks ill try that and get back with a solution or not.
    Dec 2014
    joplin mo
    Re: new to the site
    update! it was a bad injector. checked with that airtex site and they didn't list an injector. just fuel pumps. i ordered one through oreillys. i get a discount there anyways, work at a chevy dealership lol. thanks for the help firefighterwhite89!
    Re: new to the site
    wow that is one problem solved. this is why i love the website.
    Jul 2009
    Somerville, Alabama
    Re: new to the site
    You're welcome. I've had the same annoying issue before.
    Shaggy
    FF II/ETC I
  1. New to the site...
    By RacerX57 in forum Newbie Introductions
    Last Post: 03-12-2014, 08:17 PM
  2. New to the site. :D
    By mintygreen81 in forum Newbie Introductions
    Last Post: 12-15-2011, 04:25 AM
  3. New to the site
    By Rexse7en in forum Newbie Introductions
    Last Post: 02-22-2011, 11:10 AM
  4. New To Site
    By HondaLX88 in forum Newbie Introductions
    Last Post: 02-25-2004, 12:22 PM
  5. 4 G site?
    By kudd in forum Classic Honda Community Chat
    Last Post: 03-29-2003, 03:46 PM
