I can't find the huge trailing arm bushing for sale ANYWHERE!!
not even online...
Does anyone know what kind of options we even have with these??
Honda -> No
Napa -> NO
RockAuto -> No
...?(Is all I'm doing at this point...)
not even online...
Honda -> No
Napa -> NO
RockAuto -> No
Nope I never have either.
Might have to have someone make a solid one for you.
Yeah, that's what I found out after more searching. I was thinking of going with a spherical bearing, which I would have to get a COMA-M30, then weld in a rod or something to get the ID to 12mm
OR,
What do you guys think of this: Nolathane bushings I think will fit
If the inner lip is the req'd 65mm that we need (my old ones are actually 64.4mm, so they should hold I think) then I would only have to drop the ID 22.2mm to 12mm or so.
The only problem is, when I look at "how hard is nolathane" they say 93 durometer is their hardest, but irregardless, they all look friggin weak compared to the (hard to deflect IMHO) rubber bushings that are the originals.
Opinions/comments?
Basically we need a bushing with an OD of 65mm, ID of 12mm, 54.8mm Width for the inner piece (the one the bolt goes through) and a 40.2mm Width for the Outer flange...
In the case of the Nolathane, it's bigger in every dimension, so I can cut it down to fit, the only problem being that center metal piece needing to have something welded in.
Update, I ordered Whiteline W61608, If they're oversize I'll see if I can cut them down to fitment =]
I'll keep you guys updated on what I find. My old ones aren't ripped, yet... But one of them has visible cracks coming when you bend it more than 2mm, so I'm motivated to find a solution![]()
Challenger, Charger, 300, and Magnum performance suspension components for street, road racing, autocross and drag racing
I was looking at this company the other day they might make something custom if you cant find a machine shop to fix up what you bought.
Whiteline is pretty well known also.
Keep us updated. Need the same rear bushings replaced too!!!
Shaggy
FF II/ETC I
Honda discontinued the part?
I found them for my '88 Accord LX-i on NAPA's website. See NAPA AUTO PARTS
How close are they to ef trailing arm bushings?
They are discontinued by Honda and I'm pretty sure a direct replacement doesn't exist in the aftermarket (in the US anyway).
C|
Ef is a 88-91 Honda civic
I did, and it pulls up 26 different parts. Which one is it? It is possible that there is something out there that fits but is not listed as a direct replacement. The trick is finding it. Do you have a part number?
If you search by car model they don't have any bushings for the front of the trailing arms. They do have bushings for the upper and lower control arms though. I've also searched with the Honda part numbers and come up with nothing.
C|
We're talking about this bushing? #23 on the picture
52384-SE0-014 / 52384-SE0-023
It's indeed no longer in productionThere was still one available in Canada though. It's now in my spare parts bin
Hit up chedda an see what he can do. I know he was talking about possibly making a rear sub fame and trailing arms for us. I'm sure the cost would be high on something like that but we would be able to get parts for are cars well pass the time we die lol
I ended up converting the WhiteLine bushings I got from AU into Trailing arm bushings.
I messed up part-way, but they hold well and the trailing arm itself will not shift side-to-side on the centering pin.
I dont have pics yet, but I can post them up of the final item in the car.
Have had to rush a lot, so not much pics of the project. State told me if I didn't get the car to an emission testing station by end of Feb, I'll be out of valid registration.
Mods:
- Koni super street coilovers
- TSW Mallory 4 black rims on 215/55/15's
- TRW +1.5o camber kit
- Weber 38/38 with full emissions compliance
If you want to purchase from me, you can pay CC as I use Square and can accept VISA/MasterCard/Amex.
