Results 1 to 12 of 12
Thread: Fuel injection resistor
    Jul 2009
    Somerville, Alabama
    All plugs on my fuel injection resistor read 9.3 Ohms across the board. IIRC resistance should be 5-7 Ohms. What would cause this to be slightly higher in resistance? Could it be dirty terminals? Or maybe a short?
    Shaggy
    FF II/ETC I
    Re: Fuel injection resistor
    thats not much to worry about, even a small amount of resistance at the leads could cause that, you are mainly looking for one that is a lot different then the others. Since they are all the same, I wouldn't worry about it
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Quote Originally Posted by firefighterwhite89 View Post
    If you encountered dirty terminals or bad connections with the multi meter probe tips your resistance measurements can swing a bit, having all measurements reading the same can rule out bad connection. A short would typically read as an open or low resistance below 1 ohm. Most likely the cause of the increase in the resistance is due to age, material fatigue, thermal degradation which would be normal for a 20+ year old part and also reading similar resistances. regardless I would suggest to replace the box
    First of all if they all match @ 9.3 ohm, all that indicates is that the resistance increase is not isolated to one particular portion of this resistor array. However this still, exceeds the 5-7 ohm factory spec by 24%-46%, outside the tolerance rating for the resistors. Second, the increase in resistance would have an effect on the drive current required to open the injector properly when using the same pulse width signal, to little current and the injector has opening / on-time ends up with lag or doesn't work at all. Third, resistors can end up having a dynamic resistance characteristic when overstressed and /or damaged in an operating circuit, I see things like this readily on my Lab bench with 600V circuits. If the resistor is unable to hold its resistance value within its spec this can cause a problem and can damage the injector and possibly the ecu's drivers. Interconnects of any type are always suspect to contact issues, however a good contact should always be below 1 ohm.
    3Geez resident body man
    Owner of Wreck-less auto body
    Jul 2009
    Somerville, Alabama
    Is the resistor box something I can simply pursuede open and replace 4 resistors, our too much of a hassle to even fool with? Bear in mind I live in the country where 90% of the vehicles driven around here is the American made hunks of junk hence the oldest model Hondas I can find are `97+...and ordering the part new without going to a dealership is pretty much impossible. So if I have to dremel the box open, replace some electronic parts and jb weld the protective case back together, that's what will happen. I'm definitely not as lucky as the western coast guys. Seems most southerners are all 'Made in America!' Type douches when it comes to vehicles.
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    I think this may be the reason behind my injection issues. Cold or not, it still idles somewhat rougher than it should.
    Shaggy
    FF II/ETC I
    cygnus x-1's Avatar
    Chicago area
    Before yo do anything else, touch the probes together on your meter and see what it reads. Subtract that number from what you read on the resistor box. Some meters are not very accurate at measuring low resistances. I had one years ago that added an extra 2-3 ohms.
    C|
    Jul 2009
    Somerville, Alabama
    If I subtract 4.3Ohm from 9.3Ohm I get right at five ohms. Is this how you're supposed to test it? Should I go to radio shack and test a few resistors for accuracy? It is a cheap multimeter. Came from harbor freight for $7
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    I get what you mean. When touching the probes together I get between 40.5&18.9ohms resistance depending on where on the probes I cross them...wtf?
    Shaggy
    FF II/ETC I
    Jul 2009
    Somerville, Alabama
    My multimeter is on 200 ohms setting. Should I have it on another?
    Shaggy
    FF II/ETC I
    I think you are fine, those type of power resistors can be off an ohm or two anyway, and still be within tolerance, the fact that they are all consistent is more telling
    cygnus x-1's Avatar
    Chicago area
    Sometimes the outsides of the probes get dirty and don't make a good connection. It helps sometimes to rub them together a few times and then hold. You should be using the lowest setting there is, probably 200 ohm.
    I'm with lost on this one. If they all measure the same they're probably ok.
    C|
    Jul 2009
    Somerville, Alabama
    Excellent. Thank you gentlemen.
    Shaggy
    FF II/ETC I
  1. Replies: 0
    Last Post: 03-07-2012, 02:07 PM
  2. webers or fuel injection?
    By stephensimmons in forum Performance
    Last Post: 03-11-2010, 03:41 AM
  3. RC Fuel Injection
    By Pico in forum Performance
    Last Post: 08-14-2008, 10:38 AM
  4. Fuel Injection
    By igarut5410 in forum Forced Induction
    Last Post: 03-27-2007, 05:48 PM
  5. fuel injection swap
    By SlammedAccord89 in forum 3geez Accords
    Last Post: 12-28-2003, 07:38 PM
