Results 1 to 17 of 17
Thread: car has problems starting
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    ok first of the check engine light is not on as of NOW. so please dont ask me to check m error codes becuase if the check engine light is off then the ecu wont throw codes. now to the problem
    i had been driving for 15 mins = engine is warm. i go in a store for 3 minutes, come back to the car and try to start. crank crank crank crank. nothin. crank crank crank then it starts to start then bogs then goes back to off. now at this point i notice that when i turn my key all the way to where it is supposed to turn my fuel pump on, it just leaves the check engine light on. and doesnt shut it off like its supposed to. while its in this position i push the key into the ignition (mind you i already had it in i just wanted to see if it was just shorting out.) and then i hear a click and my check engine light flashes then comes back on. so i take the key out then put it pack in and then my car starts. now as another members water pump just died on him after a year of failing i dont want to be stranded. i cant wait for it to do it again then read the code because then i will be stranded. can anyone help me with this.thanks
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    SEi User
    Jul 2002
    Santa Clarita, CA
    bump
    Jul 2002
    88 accord ex-i, 88 prelude Si
    Canada
    Don't know if this is related, but if I'm driving around a bit and park for a second, my car won't start up again for a few minutes. Also, the thing you described (starting car, bogging then turning off again) has happened to me before, but that was when it overheated. Maybe a cooling related problem?
    Now:
    -1988 Honda Prelude custom
    -1988 Honda Accord (to be fixed and sold)
    Soon:
    -some big 4x4 truck
    -91 Acura NSX
    http://www.hatetofeelband.com
    1988 Honda Accord DX Sedan
    San Bruno, CA
    i think this was something mentioned in another thread, "starter problem". i have the same problem too. like if i take a short trip somewhere, ie- gas or store. then try to start it up again, nothing happens. i think they said something to do with the ignition or something.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Probably ignition switch. Next time it happens, remember to read the code. I'm pretty sure it'll happen again
    If not, then maybe the TW sensor.
    Oct 2001
    87 Accord EX , 5spd , Manual
    main relay ??
    MIKE
    '89 Accord LX
    VA
    could aslo be that your plugs aren't all firing and causing a minor flooding....could also be bad rotor button or distributor cap...both can be buggy on short trips I have noticed.
    SEi User
    Jul 2002
    Santa Clarita, CA
    would this have anything to do with my pgm-fi light coming on though.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I've got the same problem. If it was ignition wouldn't it have trouble running correctly once started? Mine has trouble starting sometimes, but seems to run fine.
    Mike
    Nov 2002
    Ridin Dirty in New York
    Could be one of ur temp sensors, it can make the car difficult to start when hot
    Accord Lxi 1988 - 4 Door
    Hi I had similar problem sometime and was doing a search and came up with this. It sounds like most of this Short-Stop syndrome is due to a partially failed main-relay.
    Look at following site It just describes symptoms like yours
    http://www.markl.f9.co.uk/howto/elec...main-relay.htm
    Hope this helps. Let us know.
    MVK
    mvk
    1988 Accord Lxi
    A penny saved is 3 pennies earned.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I think I may have fixed mine. It's been ok for about a month now. I sprayed some contact cleaner on the TW sensor clip on the thermostat housing. Mine looked a little corroded. I've got a new clip for the junk that i'm going to solder in when I get a chance. That's also something you may want to take a look at.
    Either way, I bet it has something to do with your temp sensors. I swapped out my relay with no change until I did this.
    Mike
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Might be the main relay.
    SEi User
    Jul 2002
    Santa Clarita, CA
    my sending unit has been fucked for months
    Main relay.
    mvk
    1988 Accord Lxi
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    I'd say the main relay also
    I seem to recall a repair how-to here for that relay. I read lots of troubleshooting stuff to keep my brain up to date and that main relay is always mentioned in your scenario.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Malfunction main relay does not give out ECU code!!!
    socal3rdgen, did you check your ecu code? Doesn't matter if the engine light is not on on the dash or not, as long as you didn't pull out the ecu fuse or battery terminals the code should still be there.
  1. starting problems
    By daniel70ca in forum 3geez Accords
    Last Post: 11-21-2008, 10:18 PM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. Starting problems
    By Underdog in forum 3geez Accords
    Last Post: 08-22-2004, 11:44 AM
  4. starting problems
    By tynebeach in forum 3geez Accords
    Last Post: 03-03-2003, 09:14 AM
  5. Starting Problems
    By uneek in forum 3geez Accords
    Last Post: 02-19-2003, 04:47 PM
