Results 1 to 25 of 47
Thread: CJS wiring OBD1/Vtec B swap wire harness.
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Thats right guy's it time to replace those 27 year old engine harnesses of ares and Carlos from cjswiring is just then man to help us.
    Now let get right to it. You'll have your work cut out for you as this will be a DIY wire harness kit. That means you have put it together(make your own). So this will not be for the faint of heart and you'll need to have a bit of knowledge of wiring. However it's a the best way to get a price that everyone can afford.
    There will be two options. Option A) will be an affordable basic kit for $240 shipped and will ship with in a week.
    In the kit you will receive all of this.
    325' Tefzel Wire, Assorted Sizes & Colors. normally include 10ft of wire lengths. Genealogy more than enough for A and B series Harness ends up being 8ft max depending on chassis and routing.
    25' Raychem DR25 Assorted Sizes
    Raychem ATUM 4:1 Glue Shrink Assorted Sizes
    Labels
    Generic Crimp/Splice & Ring Terminals
    Sensor Terminals/Seals, ECU Terminals
    HARNESS CONNECTOR LIST:
    • Oil Pressure Sending Unit
    • Knock Sensor(Round Style)
    • Intake Air Temperature (Intake Manifold Style)
    • Oxygen Sensor (Primary 4 Wire)
    • Alternator
    • Injector 1-4
    • MAP Sensor
    • TPS (Throttle position)
    • Idle Control Motor
    • Electronic Speed Sensor
    • Ground
    • Fan Switch
    • OBD1 Distributor plugs
    • h20 Sending Unit (for Gauge Cluster)
    • Reverse Lights(obd1 2pin)
    • Engine Coolant Temp
    • Starter Signal
    • VTEC Solenoid
    • OBD1 ECU Plugs A,B,D
    Opinion B is everything in opinion a but with a mili spec firewall bulk head plug. No fire wall plate included(but available at a additional cost). This will run $440 shipped and will take a little longer as he will have to order the mili spec plugs as the orders come. Still about two week's.
    I'm sure you guys will have questions for on how everything will work and all that. I will try my best to answer all of your questions as they pop up.
    His site is where you can buy one. Just tell him you want the DIY kit for the accord. I will be get mine(mili spec) in about two weeks. You guy's can places orders now or wait tell I'm done with mine to see how it looks.
    Here's a link to his site CJs Wiring — Home and some photos of pass work to give you a idea of what you get. Enjoy and be sure to ask all questions here first if I can't answer them I will get the information for you.
    Re: CJS wiring OBD1/Vtec B swap wire harness.
    This is a good deal especially for the mili-spec. you know I'm close enough to take my car and test it out.
    To be clear will all the connectors be new?
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    Carlos defiantly looks like he knows what he is doing, really nice quality work here and materials used and not some half-ass rat nest. I'm very happy to see that he uses the glue heat shrink, I use it on everything at work and its excellent. Even the shielded wire splice was done cleanly. The only one pet peeve i can say here is to have more wire colors to ID the conductors better, however that would drive cost up a little bit
    Looks like a concise kit to put together and for those savvy enough in electrical, this should be a piece of cake to assemble but sounds like the adaption to the 3rd gen chassis is going to have some frustrations. Keep us updated when you get your kit!
    3Geez resident body man
    Owner of Wreck-less auto body
    Feb 2012
    89/accord/lxi
    Yes everything thing will be new.
    Feb 2012
    89/accord/lxi
    Yeah I try my hardest to get the best quality and a great price. And I will agree with you there will be some headache along the way but it will be worth it in the end. He has also been given me tips on how to loom everything so I'll be sure to post that information as I do mine and maybe some videos as I go along
    Jan 2015
    Yes brand new obd1 connectors are included... I'm cj by the way. ;p
    Instagram
    Jan 2015
    If you want exact oem wire colors it can be done but price of course will go up slightly. As I explained to the op, I found it easier and faster to use as less wire colors. And in milspec harness in its truest form, it's generally done this way. If not then just 1 color. Here is how I explained I do it..
    1 color for injectors to ecu
    1 color for sensor signal
    1 color for sensor grounds
    1 color for ground
    1 color for 12v
    and 1 color for 5v.
    Then I do a conitnuity test, as you should any way to ensure a proper connection, and terminate the wire as needed. Simple as that.
    Now when it's a 1 piece harness, yes I will try and use oem wire colors as its 1 piece and no obstruction between sensor lead and ecu.
    Feb 2012
    89/accord/lxi
    Thanks good to know. And thanks for the wiring tip. I'm sure it will help someone down the road. The key is take your time and not rush through it. It's all about being efficient and double checking your work to make sure there is not mistakes. I think for me the hardest thing will be the looming process. because I've never done anything milispec and never loomed anything that way it's gonna take a moment to get the hang of it. But what you have shared with me helped.
    Jan 2015
    If you follow my ig c_zapien I post a lot of up to the minute harnesses that make. So you can see how it's done. I don't so it with evert harness as it takes up time taking pics. But you will get the idea
    1989 Lx-i Hatchback
    Jackson, NJ
    Quote Originally Posted by crx_si-r View Post
    1 color for ground
    1 color for 12v
    and 1 color for 5v.
    finally someone who actually who gave a short concise accurate answer lol. Exactly when it comes to sensors a single unbroken wire connection is the best, most people don't realize at a connector they can have an appreciable ohmic increase if the connection isn't good. I look forward to seeing more
    Jan 2015
    Here are pics of new plugs
ID:	6722   Click image for larger version.
    LX User Honda Man's Avatar
    Jul 2011
    86 LX-i Hatch
    San Jose, California
    Wow! That is an incredible price for this kind of quality. I applaud you sir! Crx_si-r is this a limited time offer kind of thing or will these be on sale for a while?
    Low loud lovin it!
    ~~~~~~~IG @the_boso_3g~~~~~~~
    Feb 2012
    89/accord/lxi
    They will be on sale for a while. Mine will be more of a test to see how Hard it is to do yourself and make to sure that everything need is there. You always have u the option of him put it together for a additional cost as well.
    Jul 2011
    86 LX-i Hatch
    Oh I'm all down for learning g how to do the wiring. I asked that because I can't get it yet and wanted to know if they will go away soon
    Low loud lovin it!
    Feb 2012
    89/accord/lxi
    They not going anywhere anytime soon. I'll also post photos and progress updates what I get mine. I'll make a short video just like I've done for everything else I've help start
    Pm sent to Carlos
    Feb 2012
    89/accord/lxi
    Ant a boy. Looks like I'm gonna get a lot for practice because I'm sure you'll be over at the shop doing it. Lol ahahahahaha
    Jan 2015
    Quote Originally Posted by Honda Man View Post
    I constantly stock the plugs, pins, wire and seals. The quick disconnect I do tend to stock a few on hand, but generally order them as they are needed. So if the quick disconnect is something you want give a boutique a week for it to arrive then ship out as a package.
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    This has caught my eye but its unlikely I will get it any time soon. Either way, I'm glad this is being made.
    1989 Honda Accord LX-I 300K+
    Build Thread
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    This is perfect! Can't wait to see the finished product 😀
    Feb 2012
    89/accord/lxi
    I need is the pinout for gauge cluster functions. Who's got it.
    for the wires in the cluster plugs?
    Feb 2012
    89/accord/lxi
    good deal.
    is there a difference between 86-87 and 88-89? because the diagram is for an 87
  1. BoomSlang Obd1 Conversion harness
    By Rendon LX-i in forum Performance
    Last Post: 03-12-2011, 09:33 AM
  2. OBD-1 Swap Wiring Harness
    By ArokASE88LXi in forum Wanted
    Last Post: 06-24-2009, 12:02 PM
  3. how do I wire up my alternator to a custom wiring harness?
    By hondaman1986 in forum Carburetor Tech
    Last Post: 03-16-2009, 12:30 AM
  4. anyone made their own OBD0->OBD1 harness before?
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 11-10-2005, 11:36 PM
  5. Replies: 5
    Last Post: 02-14-2004, 02:15 PM
Tags for this Thread
