Its an old model but really very awesome in condition.It shows that you take your car with full care.Its color is very impressive and suits according to its design.I would love to drive this cars.
i got some seats from a 91 prelude si.
they are gonna be so sweet in the car.
i also put the springs in. in combo with the tokicos my car rides so smooth now, ill take a pic or a few tomorrow after im done with the seats.
also picked up a spare air idle valve, and a spare vacuum advance for the dizzy, just in case. because you can never have enough of those things.
I <3 My CA6
some pics here. yeah the front might be a little higher than the back, but it shows more in the pics than it does when you are actually standing by the car.. i tried to do the pinch fork mod, but i noticed if you cut the fork, the little indention on the shock itself wont be lined up with the bolt. any suggestions?
the seats are in, and they are FANTASTIC. i got all 4 bolts in on each seat.
swapped the outer rails, ( rails closest to the doors ) with accord rails. drilled the hole for one of the studs for each rail, because the hole is about an inch off from the seat hole.
driver side went smooth no problems at all.
passenger side i had to shim the rail from the seat with some washers, because it sat lopsided.
the outer rails didnt line up at all, so i persuaded them to line up, and they did.
passenger seat slide is a little tight because i made it fit, but its fine.
I <3 My CA6
I LIKE A LOT! The front look higher because the wheel arch is higher in the front than in the back. The prelude seats are always a great upgrade.
Sweet car! Can't wait till my 86 is ready to come out of the garage. How low is the drop and what size tires are you running? I'm indecisive and having a hard time with what size tire/wheels to run on mine, but I know I want K-Sport coilovers. $1300 coilovers on a car I gave $300 for but hay it's a Honda 👍
thanks guys.
the springs are 2.5 drop. sprint springs, i got them from a local guy on here guaynabo89.
wheel / tire specs are.
15x8 +25 wheels.
195/50zr15 tires.
eventually ill be running some coilovers, but im not sure what ones yet.
I <3 My CA6
Looking good man.
thanks, im not sure what my next step will be.
but the first thing motor wise ill be doing is obd1 swap, and tuned with chrome.
ive got a buddy that will tune it for me.
I <3 My CA6
obd1 swap was the best mod you can do for the a20. I had mine dyno tuned and it was so much fun with the teg gears b16 mani and exhuast.
Dope
im looking for adapters though.
anyone have any they recommend?
4x100 to 5x120.
I <3 My CA6
Funny thing is that they look almost like the stock 89 lxi wheels.
Are they offset? How wide are they?
yeah ive always thought they look like the lxi wheels.
they are 16x8.5 32 offset, but when i put adapters on they will be lower offset, which is what im aiming for.
I <3 My CA6
I <3 My CA6
YEAAAAHH buddy.
got my adapters.
4x100 to 5x120.7 2 piece. 1.5 inch total thickness.
they came with all the bolts to hold the 2 pieces together. and the center bore has a interlocking lip.
ill be getting tires asap and throwing these on.
final offset with be +5.5. unless i need to add a spacer on the 4x100 side. i shouldnt need to.
I <3 My CA6
hello im from lake wales in polk county next time i come down there we can hook up i live in augusta ga also i was rear ended in my 89 lxi but i brought a 89 sei and put everything from the lxi on to the sei i just had it painted black i will post pics soon
Nice
You're gonna have to pull some decent negative camber though.
im gonna try not to.
if i cant get them to fit right im just gonna sell them and get something else.
i cant afford to run alot of camber lol.
I <3 My CA6
