Results 1 to 10 of 10
Thread: Problems with starting; idle
    Unhappy Problems with starting; idle
    Problems!
    My car starts up in the morning every time. No problem there. The problem is sometimes, I shut it off to run in a store or something, come back out, try to start it, and it wont start. I have to keep the gas pedal all the way to the floor and after a few seconds of cranking it will sputter and start out slow and finally get up to the needed rpms to stay going. It doesnt happen all the time, but its getting to the point that its done it its fair amount of times to scare the crap out of me. Also, I'll be cruising down the road doing about 35 and It will maintain it's speed without me touching the accelerator. When I get to a stop light, it will sometimes (not always) idle at 3 grand or so, then I'll get to another and it will be normal. Even when hot. I took it into the mechanic and of course, he found nothing. The engine's been scoped, No vacuum leaks, and maintence is up to par. What is the deal here, and I dont exactly have all the money in the world... what is cheap to fix this, or what would you do?
    Oct 2001
    87 Accord EX , 5spd , Manual
    check for a stick throttle ! if that happens when you shut off the car and come back your car will be flooded and won't start easiely !
    MIKE
    shepherd79's Avatar
    Falling Waters, WV USA
    i had the same problem when i bought my car. i had rebuild and clean the carb. it is very cheap, and it helped.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Shit that's all it is? I had the same problem and I was sooo pissed I went and bought a Weber 32/36. Oh well I'm better off anyways. I kept the old carb so I can re-build it when I take these mechanic classes next year. I decided to take a semester off. My parents weren't too happy with that idea.
    Oct 2001
    carb diagrams are in the service manual avialble for download in the FAQ's section !
    MIKE
    Nov 2002
    88 LX
    Nashville
    Mine was doing the same thing... I also suspected a sticky throttle cable in the cold, but it turned out to be a vacuum leak in the choke unloader diaphragm.
    Search using the phrase "choke unloader", and there's been numerous discussions about it.
    Stock 5 Speed...
    385,000 miles so far. Many more to go...
    I've been searching around the internat about 3-g carb problems. I found an interesting post that said many carb problems have a bad adapter plate "o" ring under carb,sucking air causing all kinds of problems. Everyone should begin there,when idle varies.
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    I start with a can of gumout
    ..with the car idling, spay with care around the carb and hoses..if the idle speeds up, you've found the leak...be warned that some leaks may only appear witht the engine in gear (auto) and a load on, which menas you need a helper...and by all menas do NOT stand in front of the car when doing this work...if your helper is an idiot, you'll get hurt badly..most lekas I've found on the drivers side..the choke unloader is also a big issue for fast and surging idle..mine is idling like a baby now..right after the new sparkers went in..and I know it's running good, the emission results during my recent inspection were very very low.
    Jan 2003
    1987 honda accord dx
    new bern nc
    mine does that too i think it is a leak cause i have performed the spray method and it worked.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    That o-ring also seals out coolant.
  1. lxi problem with idle surge and starting problems
    By Beanshonda55 in forum 3geez Accords
    Last Post: 07-07-2007, 01:41 PM
  2. idling problems, starting problems...
    By AccordDX86 in forum 3geez Accords
    Last Post: 10-13-2005, 10:17 AM
  3. Starting problems
    By Underdog in forum 3geez Accords
    Last Post: 08-22-2004, 11:44 AM
  4. starting problems
    By ztron in forum Carburetor Tech
    Last Post: 05-25-2004, 01:07 PM
  5. Starting Problems
    By uneek in forum 3geez Accords
    Last Post: 02-19-2003, 04:47 PM
