Originally Posted by
lostforawhile
the 81 should be 1 wire from ignition switched power in, one wire out,which is switched ground, to the negative side of the coil, and the positive side of the coil is also switched from the key, the module in the dizzy should be just like the ones on carbed three geez, I know I had an ignition module from an 81 civic in my hatch for years, it was identical to the factory one in the Hitachi dizzy, the ground to the module itself is through the dizzy case, and there should be a wire grounded to the case. asfar as an alternator, why not use one from a 3g? it''s not 80 amps, but it should be plenty of current for that car. A carbed one has two wires that need power when the key is on, and it has one wire out, which is for your charge warning light, that wire will hook up to your factory wiring, and let you keep the idiot light
