Results 1 to 6 of 6
Thread: Making a throttle spring bracket?
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Question Making a throttle spring bracket?
    Ok, I bought the Mr. Gasket dual spring and bracket. Well I can't use the fatter spring because of all the old vacuum lines. I could possibly bend them a little bit. This is what I have for materials: soldering iron kit, some alluminum brackets off an integra air intake and some left over brackets from my weber conversion. What I was thinking is soldering the alluminum brackets to the metal vacuum lines. Think that would work? Or am I missing something here? Where do you carb people have your throttle spring hooked up to, other than the throttle bracket? Thanks a lot guys.
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    no you cant solder that. what you really should do is remove the metal vac lines and then make a bracket. you can get small L brackets and other stuff like that at a hardware store. then find a bolt or hole that you can bolt the bracket to.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    i have a stock weber spring and its attached to the brake booster... i really need to get a new spring!
    Travis
    Mankato, Minnesota
    I have all the vacuum lines still. I think they're all plugged though. How do I remove them ?
    Oct 2002
    1987 accord lx
    Chicago
    Solder wouldn't hold something to the metal vacuum lines. I agree that the best way to make your new bracket stable would be to remove something from the carb that you're not using and use its bolt holes (choke opener, FIU, dashpot bracket...). Just make sure you rig something to take care of the function of whatever device you're using.
    But you might be able to secure it elsewhere. Why don't you give us a picture of your setup right now, show us where you want to install it, and then maybe I could give better suggestions.
    Mankato, Minnesota
    Well theres that little screw hole I could use that's on the manifold. (it is actually a L bracket holding the vacuum lines. Anyone know how I can remove the vacuum lines? I could just use L brackets and bolts and lock washers so it's tight. Plus it would be nice to have the extra room (without all the vacuum lines)
  1. Help!! With Exhaust Bracket
    By Pico in forum 3geez Accords
    Last Post: 09-30-2008, 10:05 PM
  2. seat bracket
    By loko84hb in forum 2geez Accords
    Last Post: 05-13-2008, 02:38 PM
  3. will alt fit in A/C bracket?
    By A18A in forum 3geez Accords
    Last Post: 02-22-2006, 03:53 AM
  4. Spring Tech Coilover spring rates
    By 89AccordLvr in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-01-2003, 10:28 AM
  5. Useless bracket?
    By Dia Fria Claro in forum 3geez Accords
    Last Post: 01-03-2003, 02:49 AM
