I own a 1986 Prelude Si and the other day when I tried to use the sprayer the whole handle came off in my hand? has this happened to anyone else? How do I go about replacing this?
I had the blinker side break on my 86 accord and couldn't find one in a junkyard. Also Honda discontinued selling it so that was a no go. Found a replacement at autozone for $330 ish ($30 more then I payed for the car) Not sure if the Lude ones are like the accord's or not but if they are you have to replace the whole combination switch. Not sure if this will help you or if I made the link correctly but here goes. https://www.3geez.com/forum/how/41956...on-switch.html
the Lude combination swtch is just like the accord and most other Honda's of this era, it's one piece, try putting up a post on prelude power, and some of these vintage Honda sites and someone probably has one, you may have to get one that has other issues and use it to repair yours
save every piece of these switches you can, you never know what you might need, I think the ludes had headlight relays, on the Accords the low beam contacts burn out
Thanks guys this helped me wrap my head around the issue! I found a diagram on all data and I'm headed to pick and pull this weekend ill post pics later.
