OK, I have a question for anyone with electrical experience.... I have an 89 SE-i automatic and the shift position indicator for "D4" in the dash does not light up most of the time EXCEPT when it's very very cold out. All the other Indicators light, EXCEPT once in a while the "P" indicator will not light when I park the car and then I can't turn the ignition off either. I checked the connector and shift sensor at the shift lever and everything seems to be making good contact and is clean.
Does this mean I have to pull the dash to find the bad/loose connection??
Thanks in advance for any help, Brad
