Results 1 to 14 of 14
Thread: Problem with egr system
    Mar 2015
    1988 Honda Accord LXi
    Hi, I am new here. I have an 88 honda accord lxi automatic and the problem I am having is that I am not getting vacuum to the egr valve when I rev the engine. I have put a a vacuum gauge on hose #16 and I am not getting anything. I have checked the egr control solenoid valve and is not activating. Can this be a problem with the ECU? I am trying pass the NOx emissions and failed as a gross polluter
    cygnus x-1's Avatar
    Chicago area
    Re: Problem with egr system
    If you don't have a service manual you can download this one:
    http://bluegreenlabs.com/Accord/usdm...-1989-full.pdf
    It has the troubleshooting procedures to track down your EGR problem.
    C|
    there are some big write ups in the EFI section as well.
    Mar 2015
    Thanks for the info. Where can I get a harness for the ecu to be tested?
    Typically, the only EGR problem that will cause you to fail emissions and NOT flash a CEL is a coked up EGR valve or coked up channels in the intake manifold. An easy test for that would be to put vacuum to the EGR valve and see if it kills the engine.
    There can be other causes of high NOx too. Can you be more expansive as to what you're trying to do?
    Mar 2015
    I'm trying to fix my car so it can pass smog.
    Mar 2003
    2004 Acura TL
    Arkansas
    So you are or you are not getting a check engine light? If not, does the light come on when you first turn the key on?
    Mar 2015
    Yes the light comes on when you turn on the key on and then goes off. When the car is on, I dont get a flashing code nor the check engine light is on.
    Mar 2003
    2004 Acura TL
    Arkansas
    The LXi should have a lift sensor on the EGR valve. If it wasn't opening you'd get a check engine light. Now that's not to say everything EGR is working correctly, but at least vacuum should be getting to the valve when it is supposed to.
    Quote Originally Posted by highend64 View Post
    This is a less than helpful reply. Maybe some description of how it's failing? Perhaps some numbers from the test might be useful, or a brief outline of what you have done to address the issue already? Maybe let us know how the car runs generally? Heck, even the state you're testing in would be good. As it is, you haven't really given us anything to go on except, "I am not getting vacuum to the egr valve when I rev the engine." I'm not aware of any reason why you should be getting vacuum under those circumstances, so why do you think this is important?
    We're here to help, but we can't do it for you.
    We know now that you aren't getting a CEL, but you haven't told us whether the EGR valve will kill the engine yet. Go and do some testing and get back to us with the results.
    Mar 2015
    I am getting about 2000 ppm on both speed. The egr valve does open when I apply vacuum and stalls the engine. What I notice is the egr control solenoid valve does not open but tested directly to battery voltage and am getting the valve to open.
    What are the speeds and what are the allowable maximums? What is your state? What else have you done to test and repair this issue? Why do you think that the EGR solenoid is supposed to operate this way? Have you performed the troubleshooting steps outlined in the Honda manual?
    Mar 2015
    Yes I have went thru the troubleshoot manual. The only thing I have not done is check for voltage at the ecu harness. The maximum allowed is around 700 for the 15 mph and 500 for 25 mph. I'm I'm California.
    Jul 2009
    Somerville, Alabama
    Quick fix:move out of smog nazi California
    Shaggy
    FF II/ETC I
  1. ....Charging system problem
    By Ayeobe in forum 3geez Accords
    Last Post: 11-13-2009, 09:48 PM
  2. Charging System Problem
    By syphrvirus in forum 3geez Accords
    Last Post: 08-13-2004, 11:32 AM
  3. Problem with component system.
    By Dibbs in forum Interior & Exterior Care
    Last Post: 09-23-2003, 04:08 AM
  4. Cooling System problem....
    By BlueSpecV03 in forum 3geez Accords
    Last Post: 02-03-2003, 10:46 AM
  5. New System........... problem
    By 1989se-i in forum Interior & Exterior Care
    Last Post: 09-27-2002, 07:34 PM
