I just bought a Bel Vector 960 Radar detector for my car...my car from the day i bought it never had a cigarette lighter so i can't use the adapter for the radar detector. My brother wired his radar detector straight to his dome light and it worked fine(he had NO fuse to the wire). Not with me...i tried each wire to a different pin...and the fuse is NOT blown since a light still works in the thing. I have tried to install a 12V adapter to install in the place of the cigarette lighter, and that will not work either...i can't find the fuse for the cigarette lighter anywhere so i can't figure out if it is blown or not. Here is my dilema (sp) either:
If someone could tell me what fuse is the Cigarette lighter to since it is not labelled anywhere so that i can possibly fix that problem. Also if someone could tell me what wire to the cigarette lighter is Positive and Negative...The wires are Red and Red/Black.
OR:
Do i NEED the 3 amp fuse that is in the cigarette lighter adapter in order for the Detector to work...if so then i can just jerry-rig the fuse in-line with the positive wire from the detector so that it is fused.
thanks
