Results 1 to 4 of 4
Thread: TSP Woes
    Mar 2015
    1986 Accord DX
    Australia
    TSP Woes
    Hey guys,
    I have an 1986 DX Carby, recently it was leaking from the intake manifold specifically from the welsh plugs I removed the manifold and put in some new plugs now my leaking issues are gone but with one problem fixed arises another.
    When I disconnected the carb to get to the manifold I took off the TSP little did I know it was under tension as its spring loaded, now I can not seem to get the tension right, and my car idles rough and the revs drop until it switches off when I put it into gear.
    Any tips/troubleshooting would be gladly appreciated.
    Re: TSP Woes
    What's a TSP?
    Mar 2015
    1986 Accord DX
    Australia
    Re: TSP Woes
    I meant the throttle position sensor, well what I thought was the throttle position sensor was actually the bimetallic spring which as it turns as out was not the issue.
    My problem was I connected hose #16 wrong, after connecting the hose to the back of the manifold where it should have been in the first place my problems were resolved.....first time owning a carbureted car if you couldn't tell.
    Re: TSP Woes
    It's always nice to find a simple fix like that. The bimetallic spring you mention sounds like the choke. Glad you got it fixed.
  1. Electrical Woes...
    By scotty_not in forum 3geez Accords
    Last Post: 11-06-2006, 04:13 PM
  2. idling woes
    By daves88coupe in forum Carburetor Tech
    Last Post: 09-13-2006, 06:55 AM
  3. Distributor woes
    By biggene in forum 3geez Accords
    Last Post: 09-07-2006, 01:11 PM
  4. PCV woes
    By Moodybluesr in forum 3geez Accords
    Last Post: 03-04-2004, 01:44 AM
  5. a/c woes...........
    By grocerygetter in forum 3geez Accords
    Last Post: 07-03-2003, 04:55 PM
