Results 1 to 7 of 7
Thread: CV will not go into the trans all the way!!
    1989 Honda Accord LXI
    Chicago
    Does anyone have any way to get the drive shaft into the trans. It is in almost all the way but I cannot get it all the way so that the trans is sealed to the cv joint. I have tried a hammer and a long pole with a hammer. Any other ideas?
    Thanks
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    is this a replacement one that you bought? If so, do me a favor and compare the end of the old one to the end of the new one and make sure that they are identical in every way.
    this same thing happened to me, and it turns out they gave me an auto axle instead of a manual. The part that made it tough was that the part number on the box was correct, but it was the wrong part inside the box.
    If that's not the case, let me know, there's a few other things you could look into.
    -Mark D.
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    gently hit the other end of the axle (the part that goes into the hub) with a rubber mallet or a hammer and a block of wood. that should pop it in.
    Jul 2002
    Twin Weber DCOE Powered 88 Honda Accord LX
    Columbus, OH
    Originally posted by 2old_honda
    gently hit the other end of the axle (the part that goes into the hub) with a hammer and a block of wood. that should pop it in.
    That's what I did and it went right in.
    Mike Clark
    Nov 2002
    1988 4Dr Accord LX-Burgandy
    Winnipeg, Canada
    Do make sure it is the correct axle. I knew someone who had the wrong one put in and it cost him a transmission as it leaked and he lost the lubricant.
    '89 Accord LX
    VA
    You either don't have it lined up well or you're not pushing past the spring clip about 2-3 inches down the shaft...I reccomend doublechecking the part and then if good try the mallet if not...the you may have something going on in your tranny.
    89 LX 5 speed
    Florida
    Hey Kevin...are u near South Spaulding Avenue???
  1. 88 trans into 86?
    By 45psi in forum Performance
    Last Post: 04-12-2012, 04:42 PM
  2. a20 trans
    By firefighterwhite89 in forum EFI Tech
    Last Post: 09-25-2011, 04:45 PM
  3. Same trans in LX and LXi?
    By DCD1278 in forum Classic Honda Community Chat
    Last Post: 09-25-2003, 02:07 PM
  4. got my teg trans
    By flamed89 in forum Performance
    Last Post: 07-11-2003, 03:40 PM
  5. 1st gen teg trans
    By PhydeauX in forum Performance
    Last Post: 09-24-2002, 04:14 PM
