Results 1 to 9 of 9
Thread: Interior lights
    Oct 2002
    89 carbed LX sedan
    Jax, FL
    Interior lights
    The door light on my right rear door stopped working, so I swapped bulbs with the other side and the bulb seemed to work fine. A few minutes later, my dome light went dark, too. I don't know about that bulb (since I don't have another dome light to test it in, and I tore the bulb up getting it out) but I suspect it's the same problem. Anyone know what the problem could be?
    Also...how feasible would it be to replace these lights...all of them...with white LEDs? I keep the way the lights look now...ie I don't want to use christmas lights or anything.
    Nov 2002
    Ridin Dirty in New York
    somtimes the switches in the doors go bad or work intermittantly
    Banned
    Morgantown, West Virginia
    I would check the fuses first. Also check the switches on the doors. They are shaped like L's. As the door closes it turns the switch off. When the door is opened, the metal touches to metal and the door lights will kick on. Take them out (2 screws and a wire behind) and work them back and forth. They may have some stuff built up from many years of use. You can swap another set in from another car, thats what I did and they work fine now. These activate the dome light too if it is set on the setting to turn on when the door is opened.
    If the dome light doesnt work period even when its in the On position, look closely at the bulb and you can see if the filament is still in tact. If the small wire is broken then the bulb is blown....if not, then its another problem!
    Nate.
    89 LX 5 speed
    Florida
    Yo...finally someone brings this up. For the pas 3 years I've been without dome or door lights. I've checked everything...I took out the L shapped switch and replaced it with another 3geez's switch...still didn't work...the only door light that works is the front right door...the dome light..even in the "ON" position...it doesn't turn on...I've changed all bulbs...replaces all switches...checked all fuses...I mean ALL...I'm still with no dome light as with 3 other doors as well...
    Is this a comon problem on 3geez????
    Oct 2002
    89 carbed LX sedan
    Jax, FL
    Maybe the fixtures themselves could be bad? Assuming the problem that's in the door lights and the dome lights is the same...it may have something to do with however they made them. A permenant solution might be to install an aftermarket fixture...in that case I might as well change to LED anyway. Or we could take a look at 4 and 5 G fixtures, and see if they're any different...they might have fixed the problem by then.
    Oct 2002
    89 carbed LX sedan
    Jax, FL
    accordboricua - did you check the grounds? I just talked to my dad, who is familiar with electrical stuff, and he said that's a possible problem. Also, the wires run through that plastic thing from the door to the post...they could be frayed or cut. I haven't checked this yet myself, but I will when it's light out.
    Sep 2003
    89 Accord 4DR Manual DX, 01 Hyundai Elantra
    York, PA
    Did anyone figure this one out?
    When I bought my accord a week ago, I'm pretty sure the dome light worked, but don't think that the trunk light worked. Just went to the Honda dealership after not finding the lights anywhere else, and swapped them out. Still no go. This seems to be the most relavant thread I've found via search, so I hope no one minds my bringing this back up
    Fiddling with a worn-looking but tough 89 DX 4DR 5 Speed, when I'm not working on the NIN Hotline..
    In Search Of: Passenger Side Rear View Mirror Plastic, Honda Steering Wheel emblem.
    May 2003
    88 Accord LX 88 Accord LXi
    It sounds like the switch in your right rear door is the problem. The switch supplies a ground to both the door light and the dome light. If you pull switch (1 screw) and ground the wire the lights should work. There may be a little spark. If they do come on, clean up the switch and the mounting area.
    If they don't come on after you touch wire to a good clean ground, check for 12 volts at bulb. If it is there, then ground the outside of socket and see if the light comes on. If it does you have a broken ground wire.
    May 2003
    accordboricua, you might have a few problems. First check to see if you have 12 volts at the dome light. If you do ground the outer part of socket and see if light works. If it does check your ground, I believe its a wire that goes to 1 of the mounting screws.
    If you don't have 12 volts check fuse #13 in under the hood relay/fuse box.
    Another possibility (although slim) is that the safety indicator is bad. I think fuse #2 supplies voltage for that.
  1. no interior lights, please help
    By Andagail in forum 3geez Accords
    Last Post: 07-20-2008, 08:56 PM
  2. Interior lights not working...fuse???
    By KrazyKlown in forum 3geez Accords
    Last Post: 01-27-2007, 09:55 AM
  3. interior lights question
    By b8er in forum Interior & Exterior Care
    Last Post: 05-20-2005, 05:45 PM
  4. interior lights
    By Hakaveli in forum Interior & Exterior Care
    Last Post: 02-06-2004, 08:55 AM
  5. My new gauge lights (plus interior pics)
    By Rick in forum Classic Honda Pics & Videos
    Last Post: 05-09-2003, 11:08 AM
