Results 1 to 23 of 23
Thread: Wilwood brake install
    DX User im_the_snoman's Avatar
    Jan 2015
    So i picked up these wilwood universal brakes and im looking for a guy to make me a bracket for them. I will pay the money to send the brakes, have them cad designed then cnc cut. Then ill sell the brackets for the material cost. Btw these wilwoods can be had for about 400bucks new. If you have an extra set of hubs and the know how then i would appreciate your help.
    Obviously i need someone quick and trustworthy, dont want someone running off with my brakes or trashing them
    cygnus x-1's Avatar
    Chicago area
    Re: Wilwood brake install
    I don't have any Accord knuckles but I might still be able to help you with this if you can give me some more information. I would need to know the following:
    What year/model car?
    What is the model number for those calipers? (or which ones are they?)
    What rotors are you intending to use?
    My day job is mechanical design and machining, but I've also made a few parts for 3g Accords and 2g Preludes, so I can definitely do this.
    C|
    Fastbrakes.com
    They sale kits for our cars. They might be able to sell you just the bracket for the calipers. Good luck and please keep us updated with pics.
    Jan 2015
    The car is a '86 Honda Accord Aerodeck.
    Wilwood 120-9720
    And im looking to use whatever rotors work.
    Need to clear 15x8 +20 work equips. I can use a small spacer if absolutely necessary.
    Quote Originally Posted by im_the_snoman View Post
    Wilwood 120-9720
    Wilwood 120-9720 Brake Caliper-NDP, 3.50" mt.
    Caliper Material: Aluminum
    Caliper Color: Black
    Caliper Finish: Black Anodize
    Weight: 4.1 lbs
    Number Of Pistons: 4
    Total Piston Area: 1.58"
    Piston 1 Bore: 1"
    Piston 2 Bore: 1"
    Piston 3 Bore:
    Piston Material: Stainless
    Maximum Rotor Width: 0.81"
    Minimum Rotor Width: 0.75"
    Maximum Rotor Diameter: 12.72"
    Minimum Rotor Diameter: 11.75"
    Mount Type: Lug
    Mount Side: Universal
    Mount Center: 3.5"
    Mount Hole Size: 0.45"
    Mount Height: 2.89"
    Inlet Thread Size
    Might be doable with a 15" rim.
    I run the Acura Type R caliper and Rotor its 11.1". I think with that caliper low profile could look at the Honda 11.8" rotors. Pretty popular size.
    Jan 2015
    Id prefer to stay with a redrilled type r caliper. How fast can we get this started? Id like to get this done as fast as possible
    cygnus x-1's Avatar
    Chicago area
    I had forgotten about Fasbrakes, and it looks like they've increased their offerings since I last looked at their site. They might very well have something that will work for you off the shelf, so I would say contact them first and see what they can do. If they can't help then let me know and I'll look into it.
    WWW.Fastbrakes.com
    C|
    Jan 2015
    Quote Originally Posted by cygnus x-1 View Post
    WWW.Fastbrakes.com
    C|
    They dont seem to have anything for 3rd gen accords
    I thought Integra brakes were a bolt on upgrade for the 3g? Wilwood makes a $450-500 kit that come with rotors, brackets and calipers for the DA Integra. Or maybe that's just the 88-89 LXi that it bolts on to...
    Quick answer is no.
    My understanding and very,very weak memory is the Integras are 10.3" rotors like ours but offsets etc means most of the parts are not interchangeable. The break pads might be the same part number as the Lxi brakes.
    The Acura Integra Type R rotor is 11.1 inches and the brake pad FSI number is D503. Different animal but close enough for a small(thin) spacer on the bracket mounting to be able to mount them to our Lxi cars. Rotors must be redrilled or purchased redrilled to the 4x100mm pattern.
    Brian at Fastbrakes has some nice kits and has great knowledge so he is the best bet for off the shelf parts. He may need his memory prompted a bit as to what our set up is.
    I usually buy his redrilled rotors but this time around I bough a set of 5 lug EBC rotors and am going to try and redrill them myself just to see if its doable at home. I don't think there is any money savings other than I am trying to stay away from Chinese rotors.
    Weight: 4.1 lbs
    Piston 1 Bore: 1"
    Piston 2 Bore: 1"
    Piston 3 Bore:
    Mount Type: Lug
    Mount Center: 3.5"
    Mount Height: 2.89"
    Inlet Thread Size
    Just to clarify those caliper list a MINIMUM rotor size of 11.75". I think you will have to find a rotor that matches the calipers. That's why I suggested looking at the 11.8" Honda rotor.
    I do not think they will work with the stock 10.3" rotor.
    cygnus x-1's Avatar
    Chicago area
    They do have a few listings for the 3g Accords on the website but you have to dig, and I'm not sure if they have a listing for exactly what you want. Really you'll need to call them and explain what you have and want to do.
    Here's a complete kit they have for 3g Accords:
    1986-1989 Accord 12.2" 4 piston big brake kit
    It uses different calipers and 12.2" rotors, which I'm not sure will fit a 15" wheel. But the brackets and rotors with this kit might work with your calipers.
    C|
    You will need to run 1988-1989 fuel injected hubs that came with 10.3in rotors.
    The ITR caliper will bolt on
    Rotors 11.1in you will need 1989 Acura Legend 4x114 Re-Drilled to 4x100
    since you have 1986 you will need to upgrade your whole front end. If you call Fastbreaks.com they have whole kits for you. I run 15 inch wheels with a 35+ offset and it fits just fine.
    damn a bolt pattern for every occasion!
    cygnus x-1's Avatar
    Chicago area
    Good point about the smaller knuckles on all but the 88-89 LX-i. Does Fastbrakes know about that? Because their listings only state 86-89 Accords. They appear to support the smaller knuckles on the base model Civics so they at least know about the different knuckle sizes there.
    The 11" kit also comes with calipers, which he already has, so that's maybe not the best option.
    C|
    cygnus x-1's Avatar
    Chicago area
    Do you know what the inside diameter of your wheels is? The outside radius for those Wilwood calipers you have is 6.69 inches and you probably want at least 1/4" of clearance to the wheel. So that would put the inside diameter at 13.88 inches. This is with the minimum rotor size for those calipers.
    C|
    I like where this thread is going....
    C|
    Not sure if they know that. I know LegendMaster was the one who worked with Fast brakes to make a bolt on kit. I just Pieced my kit together from the parts store.
    cygnus x-1's Avatar
    Chicago area
    So I've been dinking around with some numbers to see how these calipers might work, and from what I can tell so far it is rather unlikely that these will fit inside 15" wheels. The caliper bodies are just too thick, and even if you used the 11.1" Honda rotors (which are below the minimum Wilwood spec), it's still really close. The other problem is that these calipers are narrow mount, which means the mounting lugs are really long. This becomes an issue if you try to use a smaller rotor because the lugs are likely to be hitting the knuckle. The knuckle could probably be ground for clearance, but given the wheel fitment issue I think it's probably not worth the effort.
    Bottom line is, if you really want to keep the 15" wheels, the best option is probably to put together your own kit with all Honda parts (or buy the kit from Fastbrakes).
    C|
    Jan 2015
    Thanks guys. Did some mocking up and they arent going to fit under my equips which im adamant about keeping. Guess ill be putting these on my camaro and buying their kit.
    cygnus x-1's Avatar
    Chicago area
    Yeah, that's what I figured.
    C|
    keep us updated on your set up.
  1. Replies: 21
    Last Post: 04-17-2006, 07:02 PM
  2. new Rear brake shoes and new drum install
    By hondac in forum Performance
    Last Post: 11-24-2003, 04:02 PM
  3. How To , Install Civic Integra AEM Big Brake Kit
    By Knowledge Base Admin in forum How To
    Last Post: 06-24-2003, 03:05 PM
  4. how to install new brake pads?
    By zerovisual in forum 3geez Accords
    Last Post: 08-12-2002, 01:16 PM
