Results 1 to 4 of 4
Thread: how do I swap into b18a1?
    Apr 2015
    My 87 lxi had an a20a1 and I started a b18a1 swap with a friend but the wiring seems to be tricky who's done this Im lost and my friends out.
    Re: how do I swap into b18a1?
    At least you are on the right website. you will have to run a custom harness. depending on what kind of ecu you have you will have to do your own wiring.
    carotman's Avatar
    Montreal South Shore
    The wiring is easy.
    - Install your A20A wire harness on the B18A1.
    - Add the missing wires and plugs on your current harness. Source them from the B18A1 harness.
    - Use a an OBD-0 ecu or get a conversion harness for an obd1 ecu
    The wiring is easy.
    I did that and I found out some wires and connectors had to get fixed. I was having problems with my wiring so I went ahead and I got my self a brand new OBD1 harness and will relocate all the wiring from the sturt tower to go inside the car to the passanger floorboard like the civics and integra ecu location. I will post pics after the 3geez meet when I will take the car apart.
  1. 91 acura b18a1
    By 89sei89dx in forum General Engine Swaps
    Last Post: 03-07-2014, 11:20 AM
  2. A20a3 to B18a1 swap
    By enigma2446 in forum Classic Honda Community Chat
    Last Post: 11-28-2011, 09:29 AM
  3. B18a1
    By Xaisk in forum 3geez Accords
    Last Post: 09-17-2010, 06:03 PM
  4. b18a1
    By racinevrywhere in forum 3geez Accords
    Last Post: 08-22-2009, 06:49 AM
  5. Tearing down my B18A1
    Last Post: 01-03-2003, 11:25 AM
