Guess I never posted here when I first joined
Got this EFI 86 LXi Automatic last September for $600, 140XXX Miles
Needed a new starter so I got one and it ran fine, but the teeth on the torque converter were torn up because the last starter's case broke and the previous owner kept grinding the teeth. So that quickly chewed up the new starter and I replaced the TC and the starter again. Then it idled really low with a lot of missing, just adjusted the throttle cable. Did a timing belt & tensioner job, new valve cover gasket and drive belts. Broke a spark plug in the head so now Cylinder 3 has a plug in a thread sleeve sitting all cockeyed, but it works (New plugs and wires, cap and rotor). Stopped missing so bad, the old plugs had closed themselves somehow. Had an issue of dying while driving around, prominently after a turn. Opened up the distributor and had a few table spoons of rust dust fall out, tried to rebuild it but it was so gone I just replaced it ($237, Ouch).
De-studded the snow tires it came with and sold the aftermarket ones to make a quick buck (a rear one was really bent anyways). They looked good to me but they were so friggin heavy, both rear upper ball joints are out and the front ones are on their way. Looks like this now
The car looks lifted because it's on a center post lift, I just hadn't lowered it all the way to the ground in the pictures
Got an '89 parts car a couple weeks ago, currently parting it out but I'm going to swap the 5 Speed into this '86, gonna be fun!
