Results 1 to 8 of 8
Thread: Timing Belt.....
    2.0Si User 3G Jester's Avatar
    98 Av6 3oh
    Sacramento, CA
    Angry Timing Belt.....
    cars lagging like a bitch boys..help me out---how can i adjust my timiing belt. i dont feel like bringing it down to a shop---takes em a few times to get it right
    -Travis-
    98 Av6 3oh
    Sacramento, CA
    By the way..its an automatic
    -Travis-
    YK86's Avatar
    Oct 2000
    BC, Canada
    Unless your tensioner came loose for some reason, the belt usually doesn't skip meaning it doesn't need adjusting. If it's hesitating or you feel a loss of power, you may need a tune up (plugs, wires, rotor and cap, fuel filter, etc).
    www.b20accord.com
    LX User Scotts88WhiteLX-i's Avatar
    Oct 2002
    88 Honda Accord LX-i Sedan
    Eugene,Oregon
    or if you really want to adjust the timeing go to the store an pick up a timing gun an then after your done usin it take it back lol :lol
    "Its what i did"
    -Scott
    88ancient
    -Its not illegal until you get caught-
    Oct 2001
    87 Accord EX , 5spd , Manual
    there are to timing settings to be set !:
    cam , crank timing > which must be set by the timing belt and usually doesn't get changes by it self unless you have a bad belt or a bad tensioner .
    Ignition timing > which is set by turning the distributer clock or anticlock wise to advance or retard timing and you have to have a timing light for this one which is a pretty easy job !
    MIKE
    98 Av6 3oh
    Sacramento, CA
    well i know its the timing belt because the RPMs go flying up and wont change gear. plus....every other time this happend when the car belonged to my grandfather---it was the belt.
    -Travis-
    YK86's Avatar
    Oct 2000
    BC, Canada
    If the car's rpm's fly up and won't change gear, it's a tranny problem. Good chance it's a maladjusted throttle cable or non-Honda ATF.
    www.b20accord.com
    98 Av6 3oh
    Sacramento, CA
    -Travis-
  1. I need timing belt help
    By dmitch31 in forum 3geez Accords
    Last Post: 05-30-2007, 10:40 AM
  2. What do you think of my timing belt?
    By maxsideburn in forum 3geez Accords
    Last Post: 04-04-2006, 08:03 PM
  3. Timing Belt
    By 89HondaAccord in forum 3geez Accords
    Last Post: 03-10-2005, 07:54 PM
  4. Timing Belt
    By 89HondaAccord in forum EFI Tech
    Last Post: 03-09-2005, 04:30 AM
  5. Timing belt
    By 89AccordLvr in forum 3geez Accords
    Last Post: 03-20-2003, 05:13 AM
