Results 1 to 12 of 12
Thread: Proportioning valve
    Apr 2015
    1986 Accord LXi
    Proportioning valve
    Hey All, I understand this topic has probably been beat like the perverbial "Dead Horse", however, I still need some help. I have an '86 Accord LXi that has a leaking proportioning valve. It's leaking out the hole in the center of the valve body. I believe there's supposed to be a rubber plug there. I've tried to find the part and even my local dealer has told me they no longer make it. Should I try to find a plug that will fit the "weep hole" or try to find a replacement? If replacement, any ideas where to start? The car is stock, no mods. Great shape body wise, just need it to stop every now and then. Thanks in advance for your time.
    May 2012
    central Ohio
    Re: Proportioning valve
    What is the proportioning valve?
    LX User ryan427's Avatar
    Nov 2014
    1989 Honda Accord LX
    Thomasville, GA
    Are you talking about the valve beneath the master cylinder?
    89 Accord LX
    270k miles
    We've nicknamed it "The Time Machine"
    Jan 2012
    1989 Accord lx-i
    North Carolina
    That's the non pressure side of the valve. If it's leaking, you'll have to replace the valve. The inner seals are shot.
    from what i remember the seal inside goes bad. you will have to find another prop valve from the 86-87 accord. on my 89 lxi it came with a 40/30 and when i went se-i set up i used a 40/40 from the se-i. Im sure you could run a integra or civic one if you cant find a oem one.
    Apr 2015
    1986 Accord LXi
    What year Integra or Civic could I use as a replacement? Sorry it's been so long. To many irons in the fire.
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    its not really a replace as they sit different then stock so youll have to rebend some lines a bit to make them work
    Apr 2015
    1986 Accord LXi
    Will a valve from a 90's vintage Accord work? Same setup it looks like just mounting is different. I'm willing to rebend lines if needed, just gotta find out what will work. Also wondering if mine is a 35/30 or 40/40, and if I switch to a higher rating, what issues may come up?
    Feb 2012
    89/accord/lxi
    35/30 sei are the only ones with 40/40 for are cars
    My valve is leaking too. From what I can tell, they don't make these new anymore, so you'd have to buy a used one. Which is every bit as old as the one you're replacing. That doesn't fill me with confidence. Is anyone using an adjustable aftermarket valve around here? Any recommendations?
    Feb 2012
    89/accord/lxi
    It's 100% custom but you can try one of these Wilwood High Performance Disc Brakes
    Apr 2015
    1986 Accord LXi
    I thought about the Wilwood products, just not sure how to hook them up with all 6 lines.
  1. Se-i Proportioning valve (Brakes)
    By OldSchoolSwap in forum Wanted
    Last Post: 06-06-2011, 12:39 PM
  2. leaking proportioning valve?
    By rebuild in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-21-2010, 10:55 PM
  3. proportioning valve
    By lightbulblxi in forum Classic Honda Community Chat
    Last Post: 04-22-2004, 09:14 PM
  4. proportioning valve swap?
    By 98hp in forum 3geez Accords
    Last Post: 11-22-2003, 04:44 PM
  5. What does the proportioning valve look like?
    By 1989 Lxi Coupe in forum 3geez Accords
    Last Post: 12-07-2002, 10:36 AM
