MY SYSTEM JUST HAS 6 BY 9'S IN THE BACK AND SIX INCH MIDS IN THE FRONT AND MY TRUNK ALREADY RATTLES FROM THE 6 BY 9'S....I PLAN TO GET SUBS...BUT DO OUR YEAR ACCORDS SOUND GOOD WITH SYSTEMS OR IS THERE TOO MUCH RATTLE IN THE TRUNK?:pimp:
Kahsperr
get dyna mat and take the plastic out from the trunk if u want no more rattling
Travis
What I did was dyno mat and I used expanding foam for the trunk lid. You know those little holes that are on the underside of the lid I filled all of those with the expanding foam and it doesn't rattle anymore. Another thing that can rattle is the brake light in the rear window. It can rattle against the glass. I put little foam strips (black foam stuff I found) in between the glass and plastic. And that took care of all the rattling for me.
Use weather foam strips. You can find them at Home Depot or hardware store. Ask for weatherfoam for sealing windows. They are originally used for window installation, so the weather is trapped in, and so the outside waether doesn't come inside the house. These strips work very well!!! I used a LOT for the trunk and PUFF!!! no more rattle (not as much as before). Trust me, its a lot cheaper than Dynomat. I'm using weather foam strips, until I can afford Dynomat.
-ed
H4 Headlight Housing
6000k HID Conversion Kit
Strobe Light Kit in City Light Housing
Clear Corner Signal Lamps
Tinted Bumper Signal Lamps
Hyper-White Reverse Lamps
expanding foam is the best bang for the buck, its just very messy to install
i used dynamat everywhere in the trunk. i even stick that shit under the back dash, and it lowered my noise a lot. i mean a lot.
I have two twelves and infinitis and I crank it, I have a little rattle but I am more concerned @ how well our cars keep sound. You are probably still going to have to roll the windows down to share it with the neighborhood. Then they wont hear your rattle.
[email protected]
89LX-I
JVC 180 w CD Lightning Audio 10' sub, and two Bostwick XL 12's,
Pioneer Amp 760 Watts, Futura GLH II tires,
shaved trunk, HID appearnce fog lights,........ SO FAR!!
our accords hold the sound preatty good. unless you are running 1000W system, than you will scare people.
i have dynomat in my trunk and when i have my stereo on full i can hear bass, but not as it used to be.
our weak point is doors. they suck ass. i had to roll two layers of dynomat just to keep sound inside.
