Ok, well i go out to warm up the car this morning for work, and after it starts, there is some sort of grinding sound coming from under the hood. it isnt all that bad...but it is still grinding. it kinda sounds like bad brake pad grinding.
so i go out when its all warmed up, and it has stopped grinding. ok, so i though it was a fluke or something. i press the brake, let the ebrake off and push the clutch in to go into reverse. as soon as i pushed in the clutch, it starts grinding but just for a second then stops. it is in neutral, and i let the clutch out again, it starts grinding again. so i put it in reverse and it is still grinding, so i take off...as soon as i pick up speed, it stops...or it is too quiet to hear. but it only grinds if the car is rolling in neutral with/without the clutch in. so it can be rolling and grind (which makes me think the tranny) but it also stops when i am parked and have the clutch in and in neutral (which makes me think the clutch)...anyone know what this sounds like??
