Results 1 to 10 of 10
Thread: Idle Problem
    89' LX-i Accord
    Miami
    Idle Problem
    My motor rev's up and down by it self What could it be?
    Jareds 89 LX-i's Avatar
    Apr 2001
    Black '89 Accord LX-i sedan
    Mills River, NC
    EACV (electronic air control valve). Not uncommon on 3geez. It's the one right on the intake manifold under the throttle cable, with the white plug.
    -Jared
    Jul 2002
    1989 Accord LX-i Hatchback
    Western NY
    It might also be your Throttle Body...my brother had a 91 lude that did that whenever he was at rest (ie...stop sign) and when a new throttle body was installed the problem was fixed.
    www.geocities.com/geezpict/bumb
    89' LX-i Accord
    Miami
    Nope not the throttle body I have two engines I tryed switching them but got the same results. I'am thinking it might be the black box in the left corner were all those vaccum hoses go to. But not sure.
    Jun 2002
    86 Accord LX, Carb, AT
    Umm, you've got an LX-i yet you have the black box/vacuum wires under the hood? Something doesn't seem right.
    Gene
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Bleed your cooling system. If that doesn't help then try cleaning the fast idle valve at the back of the TB.
    1988 Honda Prelude 2.0Si
    Santa Rosa, Ca
    if you notice when you unplug the wire from the eacv, the car will fluctuate idle evenly, most likely, that is your problem. I bought one from honda, and it cost $176, make damn sure that's what it is before you change it, its code 14 on the ECU... good luck
    89' LX-i Accord
    Miami
    Hey Dude, all of the fuel Injection "LX-i"s in 1989 and1988 had that black box with 8 vaccum lines running out of them. oh yea and were are the eacv, fast idle vavles located at? I have the car car in my cousins shop so I can only work on it on the weekends.
    Thanx, Janiel
    Short Ram Intake.
    Pacesetter Catback.
    MSD coil.
    ACT Stage 2 Clutch.
    Custom Short shifter.
    Drop Zone Coil Overs.
    20% Tints.
    Pioneer DEH4400.
    Pioneer 3 ways.
    RF Amp, 12" HX2.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Jareds 89 LX-i has described where the eacv socket is. The fast idle valve is behind the TB. Looking from front of the car, you can see a circular metal screwed in by 2 philips screws. That's the top of the fast idle valve. Unscrew that and spray some carb cleaner in it. Wipe it down. Take it off to clean it if you want.
    LX User Whitehonda's Avatar
    Nov 2002
    Then (89 LX-i) Now (94 EX)
    Michigan
    Janiel,
    Check out this thread, it was posted awhile back. I had that same problem, and this fixed it.
    https://www.3geez.com/showthread.php?s=&t...highlight=idle
    Cameron
  1. Idle Problem
    By Fuzy Navel in forum EFI Tech
    Last Post: 11-08-2006, 11:10 PM
  2. accord lxi idle problem and start problem
    By sonusa in forum EFI Tech
    Last Post: 08-21-2006, 09:05 PM
  3. idle problem
    By AccordNut in forum 3geez Accords
    Last Post: 01-26-2005, 04:21 PM
  4. idle problem???
    By ltown lx-i in forum 3geez Accords
    Last Post: 11-18-2003, 02:05 PM
  5. Idle Problem?
    By Janiel in forum EFI Tech
    Last Post: 10-29-2003, 10:52 PM
