Results 1 to 16 of 16
Thread: Yellow Painted Screw On Carb?
    my tight ass 88 carbed lx accord!!! and a 95 teg
    atlanta ga
    OK I DONT KNOW IF ANYBODY REMEBERS ME TYPING A WHILE AGO ABOUT ME HAVING WINTER CARB PROBLEMS BUT I CHANGED THE FUEL FILTER, SPARK PLUGS, WIRES, AIR FILTER, PCV VALVE AND THE CURVED HOSE THAT GOES ON IT BUT WHEN I TOOK MY BREATER OFF I SAW A YELLOW PAINTED SCREW THAT SEEMED TO ME AS IF IT ALLOWED MORE FUEL TO GO INTO THE CARB I UNSCREWED IT 2 FULL TURNS COUNTRCLOCKWISE WAS I WRONG FOR DOING THIS WHAT DOES THIS SCREW REALLY DO. I NEED SOME HELP. MY CAR DRIVES FINE NOW NO MORE STUTTERING WHEN I DRIVE TELL ME IF I MESSED UP OR NOT.
    flipping off cops isnt a good thing?
    mods:
    Custom red and black interior by krylon, 95 gsr rims wrapped in yokohamas, apex n1 exhaust, carbon fiber hood, custom candy apple red tails, clear front turn signals, razo foot pedals, el gauges from pro car parts, carbon fiber gauge bezel, sparco color 2 steering wheel, limited editon sparco torino racing seat with 4 point clubman seatbelt, 7 inch in dash flip out screen dvd player, custom mounted kenwood flip out cd player mounted in casette holder, sei console, 2 7in. montiors to be mounted in headrest of sparcos, blue neon tubes, h4 headlight conversion with blue city lights,ngk plugs and wires
    future mod. weber 32/36 with weber intake shaved handles and trunk
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    whoah... the carb gods were on your side this time.
    Be thankful you didn't end up with a major gas leak. I mean 2 full turns without breaking the o-rings....
    Anyways you've just increased your float level... I'm not sure by how much though... there is a limit to the screw however screwing it out too far can cause flooding and maybe some deiseling if the float hits the top hat before the needle can seal the valve... but I may be thinking too much...
    Anyways, have a look at the glass window on the right side of the carb after the car has warmed up... make sure the car is parked on a level surface. the gas should be sitting between the upper and lower lines on the metal bit surrounding the glass.
    shepherd79's Avatar
    Falling Waters, WV USA
    WOW, you are sooo lucky dude. i always mess up o-ring on the float level screw. man you are one lucky man.
    Oct 2001
    87 Accord EX , 5spd , Manual
    a little glass window ????
    MIKE
    shepherd79's Avatar
    yeah mike it is on the same side where there fuel line comes in.
    you should be able to see it
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I didn't know there was a glass window. Is there one on the Weber 32/36?
    Oct 2001
    thanx Alex ! everyday i keep on lerning more and more
    shepherd79's Avatar
    about the weber you will have to ask mike. he is on the way from germany right now, may be he is home by now.
    But if i remember correctly there are no glass window on weber. you will have to take the top off and adjust the float manualy. which makes more sence in having less parts to mess with.
    SEi User 2old_honda's Avatar
    Nov 2002
    88 Accord
    Nebraska
    no
    atlanta ga
    so does this mean i should screw it back to its orginal postion?
    mods:
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    well if it runs good and everything than leave it how it is.
    atlanta ga
    but now i am having to hold my foot on the gas while turning the key is anyone else starting their car this way. keep in mind i changed the rear fuel filter as well with the plugs wires, pcv valve air filter, and the curved hose that the pcv valve goes into i really need to know whats going on i never had to hold my foot on the gas while turning the key before. before n e one asks i do pump the gas 2 times before attempting to start. so can someone help me why is my car starting this way? also there is a new honda brand starter on there too.
    mods:
    shepherd79's Avatar
    ok, after you turned the yellow screw did you check the fuel level in the bowl?
    what is it?
    atlanta ga
    bowl? i dont know where that is i need to know do i need to screw it back cause i dont like starting the car like that i am used to pumping the gas a few times and turning the key hey shep. do start yours this way?
    mods:
    shepherd79's Avatar
    take off the carb cleaner, the glass window will be on the right side of the carburator. if it is full of gas than you will have to screw it back in. just don't do it too much or you may go back to your original setting.
    no my car doesn't start like that anymore. i don't have all that electronic crap anymore.
    89 Honda Accord Lx
    Ontario, Canada
    actually what he had turned was his automatic choke screw. makes the car rev lower or higher. which two full turns would make the car rev higher but also run better
  1. 1988 accord three door carb idle screw set...
    By lakeside888 in forum Wanted
    Last Post: 10-01-2012, 03:54 AM
  2. yellow 2 u all
    By sleepn2.0 in forum Newbie Introductions
    Last Post: 02-26-2005, 06:57 PM
  3. Yellow SE-I??
    By KoNEY in forum Classic Honda Community Chat
    Last Post: 03-20-2004, 12:26 PM
  4. Yellow 3 G????!
    By MyGarbageLXi in forum Classic Honda Pics & Videos
    Last Post: 08-14-2002, 03:40 PM
  5. carb screw question
    By StolenKar in forum Carburetor Tech
    Last Post: 08-14-2002, 03:51 AM
