i am having some issues with my under dash fusebox.the ac and low beam headlights fuses seem not to making good connections is threre a simple way to remove box to see and work on it ?are there plug in harrness i can see what looks like 10mm nut on right side of box is there another on left side behind steel beam?must be someway to be able to tighten connections up or bypass.with a inline fuse and possible switch. thanks for any replies Bill
