86 accord DX...carb
New radiator with no damage on installation.
New genuine Honda thermostat (180*)
New genuine Honda thermosensor in tank (stamped 90M as they all are).
Honda blue coolant pristine.
New Aisin water pump with excellent flow.
Everything is sealed up right, no leaks
Head gasket is fine up & down that checklist....just the fans don't come at temperature.
Both radiator hoses heat up appropriately, when thermostat opens.
I've been through 7 junkyard switches, 7 aftermarket switches & the beck arnley switch, all 90*C
Purged air from every hose through bleeder bolt with heater on high til I couldn't get a single bubble, while parked on a hill with the nose up higher.
COOLING FANS COME ON WHEN JUMPED WITH A WIRE AT THE CONNECTOR, ALSO WITH THE AC ON.
Relays are good and fuses too, which I guess is obvious if jumper and ac override work.
DX model with a carburetor, no box under passenger seat for timer, just the switch.
I'm stumped and I could use some advise on the best path forward, thank you.
