Results 1 to 18 of 18
Thread: Airbags??
    Jan 2003
    89 LX-i 5-speed sedan
    Question Airbags??
    :pimp: Hey fellahs, I gots a querstion.... I want to put my Accord on air bags! I want FBSS... the question is, what do I need to do it? I mean, I know what I need, but is there any vehicle specific parts, or will it all have to be custom? I know that trucks on airbags have a section cut out of the bed, and I wouldn't have a problem doing that in my trunk, because it leaks anyway... the only problems I can think of right now, is the tanks... I COULD remove the back seat, and make a custom box to hide them
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    talk to tk89acc or pearldrop. They've both bagged their cars so they can def. point you in the right direction. Good luck man. Post progress.
    -Mark D.
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    You are going to need to run air cylinders. You can buy it all separately to get the exact kit you want but it basically doubles the price of buying it in a kit. I know that through AIM or the Hack Shack you can get a bolt on kit for your car for under $1500. That means no cutting. The tanks are pretty easy to mount in a small area even though I would recommend two three gallons instead of a six gallon (don't go any smaller than five gallons total)
    I'm not going to make a complete list because there are a lot of fittings and things you will need to mount everything.
    cylinders and mounts specific for your car.
    compressor
    four valves
    air line
    switches
    air guages
    fittings
    zip ties
    pressure switch
    a lot of wire
    S.Glastonbury, CT
    If I didnt buy my Konis i would think about doing bags or cylinders but dont know much about them other than what i read in other postings. But i have a few questions:
    What determinse how low it sits when the car is off and i would imagine you let the air out but is this a pre set height?
    And do you guys have camber problems cause im assuming you lift the car to drive it?
    Dumb questions but i have never really looked into them and very few people have them that i have seen at local shows. Thanks Rob
    Jan 2003
    alright....thanks for the info.... does the hack shack have a website? wait... I saw an ad in one of my import tuning magazines, but they don't have any shops around here.... Oh well, I'm sure with all the people on airbags around here, SOMEONE will know how to install it!
    Feb 2001
    NW Wash.
    Most people just drop it all the way when they park. As for driving height there are several different things you can do.
    1. not worry about alignment
    2. Choose a ride height that you like and mark the pressure on the air guages. Then get an alignment at that height. Whenever you have that amount of pressure in the bags/cylinders the car will be at the same height. Sometimes it takes some playing to get the car to the right height because they are so fast.
    3. Use regulators and an extra set of valves. That way you can set it up so you hit one switch and the whole car goes to that exact ride height. Then you can get an alignment with camber kit if you want. This is the best way but it costs a lot more.
    And the website for The Hack Shack is www.excentrixauto.com
    Aim Industries is www.aimind.com (They have a terrible reputation though)
    One of the best kits you can get is available from www.brislands.com
    I am getting the kit from airlift for my car. It isn't available for 3rd gens yet but the design of the bag (yes bag, not cylinder) allows for it to slip over tokico struts. www.airliftcompany.com
    I hope this helps
    SEi User Y3G's Avatar
    05 G6 for now
    Niagara Falls Ontario
    i would love to have air ride in my car but in canada air ride is expensive!!!(2500-4500)
    swan it doent say where you are from in your profile but if you are canadian try Underworld Customs in toronto they are a airbag and body drop specialists they know what they are talking about
    S.Glastonbury, CT
    Thanks for the information. I wish i thought of it before but my syspension is pretty new and probably could sell it easy if needed but i will think about it after the motor and stuff is done.
    Jan 2003
    noooo..... I'm faaaaaar from Canada... I'm from Alabama...... yep... far
    Anyway... I MAY not get bags or cylinders, just get it lowered... I'm not sure yet......it depends on if I want to drive it like I do now, or "low-ride"... now I drive like a bat outta hell, and its gonna screw my car up because its completely stock..... I heard that bags are REALLY heavy, so I don't know what I wanna do
    89 accord lx 2dr
    ontario canada
    UNDERWORLD customs is in Burlington i know the owner and they can hook u up with anything hydros or bags they do it all they get alot of busniess from toronto but their in burlington on mainway dr in between walkers and gulph ln in the spectrum flooring parking lot u will see the spectrum sign
    89 lx 2dr 20% tint neons inside licence plate huge muffler tip painted interior blue shift bag seat covers and flof mats and sony MP3 deck with clairion amp and mephis subs 10''
    Feb 2001
    NW Wash.
    My whole box with everything in it weighed twenty pounds. I will bet that if you weigh all four struts and springs it will be pretty close to the same.
    Weight isn't the problem.
    If you like driving fast and performing very well, then don't get air ride.
    It can handle decently well (better than stock) but nowhere near as good as a performance suspension.
    Air is for cruisers. It is a lifestyle.
    LX User uneek's Avatar
    90 Civic DX
    Hastings, Fl
    Don't forget about saying reinforce your whole bottom like hydrolics
    Feb 2001
    NW Wash.
    That isn't necessary unless you plan on hopping it or doing three wheel a lot. I only have front and back on mine and I have adjustable valves that makes it drop slowly so there is really no reason for having it on mine. I don't care about being able to show off. I do it to be able to park the car super low.
    LX User Twisted 87lxi's Avatar
    1987 Honda Accord 4dr Lx-i
    Reno, Nevada
    Hrm, you guys talked me into it, I guess I know what i'm getting to replace my cut springs
    3geez Member Since August 11, 2001 (since before the server swap in May 02)
    Reno, Nevada
    90 Civic DX
    Hastings, Fl
    I would if i didn't have a hatch but i don't think it would good on a hatch at all so im not going to
    Jan 2003
    1988 Honda Accord 4Dr
    KC
    I got the hookup in KC on bags... ($700-$900) www.streetridershydraulics.com they are tight.
    05 G6 for now
    man i need bags
  1. Glad our 3Geez don't have Airbags
    By bushbean in forum Classic Honda Community Chat
    Last Post: 05-08-2007, 08:14 AM
  2. driver/passenger airbags in a 3g?
    Last Post: 02-06-2006, 07:32 PM
  3. check out this BS! AIRBAGS IN AN 88 ACCORD
    By bradccool in forum Classic Honda Community Chat
    Last Post: 04-18-2003, 01:47 AM
  4. Jim.... ...anyone really... ...airbags!!
    Last Post: 09-05-2002, 11:33 PM
