Results 1 to 5 of 5
Thread: What spark plug heat range for E85?
    Weird little deal here. I changed out a very old worn set of NGK 6 for a new set of 5's a few months ago. Replaced the cap,rotor and wires at the same time cleaned the TB etc. My usual Spring tune up. When I did the clutch I had the distributor out and cleaned it up pretty good and it seem to be ok not to worn but original.
    Since then cars idle and off idle response has really been bad. I went back to adding 2 gallons of gas to my e85 tank but it has not really made any difference in running. It also appears that the AC idle boost has quit again or the idle loaded is so bad it cant compensate for the load.
    I guess I am a little baffled that one heat range different plug would make it run so poorly.
    The old plugs were way way worn. I let them go about 3 years. Total bitch getting them out which is another story..Gaps were about .060"
    Only other odd thing is warm starting sometime the started kicks back real bad like the car is under compression some how. its a rebuild a few years old so it could be just going bad hot. But sometimes I suspect one injector maybe leaking. there RC engineering 250cc I have had quite a few years. I dont think they are rated for e85 at all. MPG is same as last year running about 24 mpg with E85.
    Re: What spark plug heat range for E85?
    Updating this a little.
    Been running a wideband gauge pod all week and I am noticing after the first run then cool down of the day the car runs very lean 15.5 or more until its fully warmed up again. The throttle is very hesitant until the O2 goes back to 14.7 normal run. My fuel pressure is a steady 40 psi and the fuel filter is about 3 months old.
    Starting to suspect the fuel pump might be going bad or again the injectors. I have new both but not ready to set them in as of yet.
    DX User Samwise's Avatar
    Aug 2011
    '89 DX Sedan (RIP), Very Special '87 LX-i Hatch
    The stoich value of E85 is 9.8. You're running it lean as fuck.
    I cant get the gauge to flip from gas to E85 but its running pretty good. Your right 15 would be way lean on E85.
    I swapped to 320cc injectors a while back to get the full throttle performance back up but all is good otherwise. I think I run about 40 psi of fuel pressure maybe 38.
    The little glitch with it lean is after the car cools some after a long run. It goes back to 14.7 it about 2-3 mins once the engine temp stabilizes.
    E-85 Facts & Myths - Page 51 - Yellow Bullet Forums
    last couple pages of this thread probably helped me out more than anything ever has.
  1. Spark Plug Help.
    By Metal_GearRex94 in forum Performance
    Last Post: 09-10-2012, 02:35 PM
  2. Spark Plug gap?
    By Rendon LX-i in forum Forced Induction
    Last Post: 01-29-2009, 09:34 PM
  3. HELP spark plug!
    By FyreDaug in forum 3geez Accords
    Last Post: 02-21-2006, 09:51 AM
  4. msd spark plug wires yes or no?
    By 3rd gen 89 se-i in forum EFI Tech
    Last Post: 03-19-2004, 02:36 AM
  5. spark plug gap
    By Morbid Intentionz in forum Performance
    Last Post: 09-28-2003, 07:35 PM
