I figured i would ask before i start reading the Honda Manual but heres the deal my winter accord wouldnt start christmas eve after i shut it off then i got a jump and started no problem. I got a new battery and put it in and i was driving at night and the lights would kinda flicker and dim occasionally so i swithched cars for now. But when working on it the starter was real loose and so i took it out to test it and its fine so put it all back and check fuses etc. The battery tested between 10-11v so its a tad lower than it should be but even with a jump nothing. Everything seems fine but dont turn over at all. But the other day it did start then it stopped turning over. I just want to see some thoughts cause i hate working out in the cold/snow and the book will give me a lot of suggestions. Thanks Rob
The Altenator is about a 1yr old from Honda so im hoping/thinking thats not the problem but very well could be part of it.
