Results 1 to 8 of 8
Thread: advancing the timing how?
    LXi User 89accordboi's Avatar
    Nov 2002
    '93 Integra
    portland
    alright, so i was talking to slammed89accord on aim and he said he had his timing advanced, and i asked how much it was, and he said u do it ur self, u turn the distributor towards the windshield and then tighten the bolts back down and thats it... is that true? he said it helps a lot... is that all u have to do? how come no one has told me this before, i mean i ask thousands of questions and i still dont know about this topic haha... thx everyone...
    Jan 2003
    1986 Honda Prelude
    Vancouver BC
    ya i did that today on my lude...what you do is losen the bolt holding the distributor and then you pull it slightly to the winsheild....not too much, or else you might f" somethin up...i COULD be wrong but im pretty sure you dont wanna go more than 1/4 of an inch
    i used a timing light on mine, so i knew exactly when to stop so my timing is right on
    -Bryan
    Inferno21 - 1986 Prelude 1.8L
    check out my car at http://www.cardomain.com/id/inferno21
    1988starter
    Guest
    Go get a timing light for about 50 bucks I use mine all the time.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Sorry but I've to do this. Wear your glasses dude.
    https://www.3geez.com/showthread.php?s=&t...ghlight=timing
    Oct 2001
    87 Accord EX , 5spd , Manual
    you may need to ryn higher grade fuel if the car pings ( ticks ) while accelerating !
    MIKE
    shepherd79's Avatar
    Falling Waters, WV USA
    i have to agree with Mike. Advancing your timming is helping, but you will have to use high grade fuel. if you don't, oyu will nottice detonation or some engine noices.
    Nov 2002
    '93 Integra
    portland
    so if i advance my timing will i get a noticeable increase in power?
    shepherd79's Avatar
    not really,
    you won't see much of power. i had it advanced for a while, but than i turned it back.
    the reason you advance is that you will move the spark point higher on RPM band. that means the spark plug will ignite hotter at higher RPM than lower.
    because our carbed engines luck power at low end, i wouldn't do it.
  1. Advancing Timing
    By igarut5410 in forum EFI Tech
    Last Post: 04-05-2008, 10:57 PM
  2. Advancing Timing
    By bushbean in forum Carburetor Tech
    Last Post: 04-14-2007, 05:01 PM
  3. advancing timing???? HELP!!!
    By cdscowboy in forum 3geez Accords
    Last Post: 09-20-2003, 08:27 PM
  4. advancing the cam timing?
    By Mantis88LX in forum Performance
    Last Post: 06-15-2003, 08:37 PM
  5. advancing carb ignition timing
    Last Post: 01-19-2003, 10:59 PM
