Results 1 to 8 of 8
Thread: MSD blaster coil 2
    LX User Xaisk's Avatar
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    MSD blaster coil 2
    I was thinking about going with a blaster coil 2 as I had some great success with the SS that I put in my old 3rd gen a couple of years ago. I cant seem to find a definitive answer but do I need a ballast resistor installed with it? Installing it wont be hard but I dont know if ill need that to keep from frying anything.
    Re: MSD blaster coil 2
    Quote Originally Posted by Xaisk View Post
    See if you can find the specs for the coil. I know the stock one is like 1.4 Ohms off hand. Most of those performance coils run about 1 Ohm.
    I just bought a stock replacement UF63 and it Ohmed out .4 on the primary. I havent tried it I dont know if the ignitor could handle it. I have emailed Standard parts and see what they say about it.
    Feb 2010
    1989 Accord Sedan
    Oklahoma City
    This is what they had posted to their website. Im not very fluent with electricity. I can wire things together and what not but I dont have much understanding of ohms or really any electrical term.
    Coil Specs
    Turns ratio: 100:1
    Primary resistance: .7 OHMs
    Secondary resistance: 4.5K OHMs
    Inductance: 8 mH
    Maximum voltage: 45,000 Volts
    Peak current: 140 mA
    Spark duration: 350 uS
    Weight: N/A
    How Ignition Systems Work
    kinda wordy but this will get you started.
    The primary resistance is the one to key in on. Thats half what a stock coil runs.
    LX User 2ndTimeHondaOwner's Avatar
    Dec 2014
    86 Accord DX four-door sedan
    Yakima, WA
    Don't think this is the correct place but it about the MSD6. Does anyone know if the MSD6 would replace the electronics in the dizzy? The little square box and magnetic pickup on mine may be going out, I'd rather just use the MSD system if I could. Thanks.
    Quote Originally Posted by 2ndTimeHondaOwner View Post
    You would still need a good pickup to trigger the box.
    Dec 2014
    Yakima, WA
    Doesn't the MSD6 have its own magnetic pickup? Maybe I'm thinking of a different one, would love to run only MSD if I could. I have a 15 year bonus from work coming soon, gives me 4K to play with
    Any ignition has to have a trigger:crank sensor or cam sensor or magnetic pickup or Hall effect pickup or IR pickup:TDC r ference preferably at me minimum< something reading each revolution of the crankshaft
  1. Opinion on blaster coil?
    By maxsideburn in forum Performance
    Last Post: 01-18-2017, 03:03 PM
  2. msd blaster ss coil install
    By 88accordSF in forum 3geez Accords
    Last Post: 05-31-2007, 09:57 PM
  3. testing MSD Blaster 2 coil
    By maka_RTH in forum 3geez Accords
    Last Post: 12-12-2005, 05:25 PM
  4. Blaster 2 coil for sale
    By 1988starter in forum Trading Post
    Last Post: 04-29-2004, 06:55 AM
  5. FS: MSD Blaster Coil 2
    By anchovies in forum Trading Post
    Last Post: 09-13-2003, 10:03 PM
