HOW MUCH WAS EVERYTHING!!! INCLUDING LINKAGES< TYPE OF MOTOR< AND LABOR!!! IM JUST WONDERING
I would say it will start at 2k and up. When i did my JDM A20 it was about that cause i spent $1300 in parts alone. Unless you get deals on stuff then parts will add up and most motors i have seen are not in drop in condition meaning they will need water pump etc. That was for just an A20A. I estimating the B20A will run me around 5k unless i cut corners and save money but as of right now im planning on having JG Engine dynamics do the block and head for me. (Higher compression) so it adds up fast especially if you need mounts and stuff. I dont know about labor because i do all my own labor.
almost free... lots of time tho
the motor is gonna be a low miles A20 from a Lude SI... i have the convert it to carb then drop it in... same linkages, samn mounts...
Travis
