Results 1 to 12 of 12
Thread: molding clips
    Oct 2002
    1987 Honda Acoord Lxi HB
    Knoxville,TN
    molding clips
    one ofmy door moldings is just flapping around 'cause I got no clips. every time I try to get some off a car at the junkyard I end up breaking them. what is the best way to get them off? can you buy new ones ?
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I'm sure you can buy new ones but, I bet they're more than your willing to pay. I got one off a rusty lxi (broke right off)
    LXi User 87Hybrid's Avatar
    2002 Chevrolet Silverado, 87 Hybrid Civic, 76 Chevy Blazer, 2000 Jetta, 1985 Civic sedan
    Battle Ground WA.
    Remove the door panel and squeeze them from the inside of the door to push in the retaining tabs and push them out.
    "AAHHH Teamsters, If only I could be as lazy and surley as a Teamster." Quote by Homer Simpson
    SEi User
    Jul 2002
    '89 Accord LXi Coupe w/Sunroof
    Santa Clarita, CA
    you can buy the clips form a honda dealrer. however they are $2 a piece.
    ACT Stage 1, Short Ram Intake & 2.25 Dynomax custom catback w/4inch carbon fiber tip. Thats it for now.
    Putting the paint back on after
    SOMEONE STOLE MY PAINT!!!!!
    10/Honda/Ridgeline
    NJ
    use some slicone sealer (glue) and use it to stick it. Dont worry about clip and stuff.
    Vanilla Sky's Avatar
    1999 Penalty Box
    nevermind... i figured i may need them in the future...
    SEi User
    Jul 2002
    Santa Clarita, CA
    hey can i buy them. im repainting my car and i tore off all my old trim. so id rather just rip off some trim and the junk yard and get more clips rather then fucking around with the inside of the car to pinch the junkyuard clips
    1999 Penalty Box
    well, since you're repainting, just go ahead and shave the shit... learn to do it yourself, man... i'll have to count them... i may still need them due to the lack of a welder and supplies... i need to remember i ain't got the junkyard in my pocket for trivial things like that...
    so nevermind that i have them for sale... dumbassed me needs to think a bit
    1999 Penalty Box
    oh, by the way... they make a tool to pull those clips... they cost less than $10... i just got lucky with mine, ripped em all off
    10/Honda/Ridgeline
    NJ
    IF it was my car, i wont bother with getting clips for 10 bucks, when i can use something like a sealent or glue that would cost me like 2 bucks the max and fix up the whole thing. and that is, if it was me and with my car.
    Banned
    Morgantown, West Virginia
    You cant reach inside the door and squeeze them out. There is metal in the way.
    You can buy them at the honda dealership, or on hondautomotiveparts.com, they are pretty expensive. About ?$2.50 each if I remember correctly. Remember that the small peices of moldings (atleast on the fenders) have larger clips then the larger peices on the doors.
    Nate.
    89 LXi coupe/99 EX sedan/02 Accord EX V6
    I took a bunch of clips off a few accords from the junkyard. It was easy to do when there are a few accords at the yard. Work from the front to back. First remove the trim piece on the fender. Next remove the little nut holding the trim to the outside edge of the doors. Then you shut the door and lightly tap and wiggle the trim around the spot you just loosened on the trim and slide the entire trim foward and it should slide right off and most of the clips will either be still on the molding, on the ground, or still in the door. Hit up a few cars and you should end up getting all the clips that you need.
  1. Replies: 0
    Last Post: 05-18-2009, 08:13 AM
  2. 79 accord plastic clips
    By BotchedExperiment in forum 1geez Accords
    Last Post: 10-03-2007, 07:25 PM
  3. Had some door molding clips made...
    By offthahook in forum 2geez Accords
    Last Post: 11-03-2006, 07:51 PM
  4. outer door clips
    By justin79 in forum Interior & Exterior Care
    Last Post: 11-18-2005, 11:25 PM
  5. sound clips?
    By 2old_honda in forum Performance
    Last Post: 03-14-2003, 04:12 PM
