Results 1 to 11 of 11
Thread: pre amp output
    LXi User 89AcCOrDmike's Avatar
    Nov 2002
    94 Ex accord 5spd (coupe)
    Washington
    pre amp output
    alright so i'm now runnin two rockford fosgate 12's in the back powered by half an xplod amp. But my deck just broke, some dumb ass broke the face for it, and i can't listen to my tunes ,but i was wondering if i could hook up my old cheaper deck that has no sub preamp outputs and would they still kick? just until i get my new deck, thanks!
    mike:super:
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    no you would need to by an adapter that converts the ohms to the correct level. I think circut city has them. PM bobs89lxi and he'll explain it in more detail.
    ~Nathan~
    "There's always something waiting at the end of the road. If you are not willing to see what it is, you probably shouldn't be out there in the first place."
    ~StOcK PiCs~
    SEi User 88 Accord DX's Avatar
    Jul 2002
    '95 del Sol VTEC
    San Angelo, Texas
    what the diff between the amp being hooked up by pre amp and it being hooked up by the speaker inputs?
    -T.C.
    Originally posted by HostileJava
    are you making fun of me because I think coroncho80 is hot?
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    What you are referring to is an impedence matching transformer. You tie the speaker outputs to the input side and there are two RCA jacks on the output. If the head unit has only one set of speaker outputs, you can use a pair of RCA "Y" connectors to split the channels into two sets, for front and rear. You will have balance but no fader control. if you have front and rear outputs, two transformers are required.
    Jul 2002
    1989 Accord LX-i Hatchback
    Western NY
    The pre-amp sends out a bass signal only and if you hook them up into the speaker inputs the head unit will play the subs as if they are just mid-range speakers...leading to 12" mid-range with little bass...you wouldn't get much
    www.geocities.com/geezpict/bumb
    Nov 2001
    If you want to run your amp using the speaker wires you will need to do as Bob posted... the Pre-outs are designed to use RCA wires to directly connect to your amp and there is usually a 2-4 volt power option with Pre-outs...
    ~Nathan~
    ~StOcK PiCs~
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    Not to mention the fact that the input impedence of a typical amp is 1000 Ohms as compared to the 1-8 ohm impedence the speaker drivers are designed for. With all the loading, and lack of shielding on speaker wires, the distortion would be tremendous. There is also a distinct possibility you could blow the input stage of your amp. Use the transformer.
    Nov 2002
    Ridin Dirty in New York
    You MUST use a transformer specifically designed to do that. BTW using the speaker level to drive the rca converter sounds like ass. But without it youll waste that amp very quick, prolly taking out the subs too, dont risk it.
    Nov 2002
    Washington
    alright nevermind i found out my deck has low rca outputs, which i guess are the same as pre amp, so thanks for all your comments
    Nov 2001
    you never looked at the back from the start????
    ~Nathan~
    ~StOcK PiCs~
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    ur amp might have SPEAKER level in
    Travis
  1. output shaft problem
    By wallacefan in forum EFI Tech
    Last Post: 06-20-2008, 07:40 PM
  2. Need A High OutPut Alternator
    By nswst8 in forum Interior & Exterior Care
    Last Post: 07-18-2005, 05:15 AM
  3. Factory Alternater Output
    By bigbrat41 in forum 3geez Accords
    Last Post: 06-07-2005, 12:12 PM
  4. output voltage question
    By mykwikcoupe in forum Interior & Exterior Care
    Last Post: 10-18-2004, 06:52 PM
  5. where can i get a high output alternator for my car.
    By NOAHS88accord in forum Interior & Exterior Care
    Last Post: 06-24-2002, 09:14 AM
