Results 1 to 16 of 16
Thread: How low can I go with this...
    SEi User jigga225's Avatar
    Louisiana
    Question How low can I go with this...
    Whas up all.
    I went to the 'yard and hustled a set of prelude arms today, and my next step is to buy the springs...
    I wanto to go as low as possible BUT here are my specs:
    Rims: 17 x 7.5 and 42mm offset
    Tires: 215/40/17 summitomo
    I want to do the 2" all around, but I'm worried about the wide tires(215) and inward offset (42mm) rubbing the suspension.
    I'm not worried about the fenders thought, cuz I'll roll them bad boys...
    SEi User TeKKnoTeKK's Avatar
    Mar 2002
    88 Accord LX-i 5 spd.
    UT
    I don't think you have any limitations here man....as long as your tires aren't rubbing on the suspension now they won't. When i put my 18's on before lowering it my tires were VERY close to the suspension (wishbone). After that I lowered it 2.5" and I'm still good, the suspension moves with the wheel. The only thing that might play a role is the 42mm offset....my 18's are 45mm offset but I would think that would even it out since your wheels are an inch smaller.
    -Aaron-
    Mar 2002
    UT
    BTW....my 18's are 7.5" width also and I am running 215/35's. Peace
    -Aaron-
    LXi User pearldrop's Avatar
    Feb 2001
    93 Prelude Si..shaved and bagged - 96 S10 bagged and bodydropped, 99 Suburban dropped 5/7 on 22s
    NW Wash.
    You won't have any problems rubbing the suspension, just the fenders - especially once you put in the camber kit. A 42mm is farther out than a 45mm offset is so it is actually farther away from the suspension.
    Louisiana
    thanks
    thanks for the help and giving me assurance by telling me what you got and your experience guys.
    I'm ordering the springs tonite.
    i have no problems with my setup, didnt have to roll my fender either...
    17x7 40mm offset
    205/40/17
    2" drop
    prelude arms
    3Geez Veteran 87AccordsterLx's Avatar
    Nov 2001
    1991 Supra Turbo W/ 12k Miles
    Wyotech @ Laramie, WY
    hey can someone explain why we dont need camber kits for the rear tires??? Thanks...
    ~Nathan~
    ~StOcK PiCs~
    86 Honda Accord LXI HB 5-sp
    Central California
    Errr, I thought I'd seen several people say they needed rear camber correction when the went below 2" drops. Anyone want to comment on this. People with 2" and lower drops that is,
    Mar 2002
    UT
    Well I wish I knew lol...guys at the tire place said I only needed camber kits for the front, then they aligned it and that was it. The reason why I couldn't tell ya, I'm pretty sure it's because lowering it doesn't effect the camber in the back as much as the front. Or it's because you can make a larger adjustment in the back than the front? lol
    -Aaron-
    LX User 89accordhb's Avatar
    1989 LX-i HB (sold), 1995 VW Jetta VR6
    Cincinnati, Ohio
    I got what is called a shim kit in the back. Essentially it is just some washers and spacers that go on around the connection of the upper control arm and the wheel well.
    LX User Akuma's Avatar
    2000 Civic
    Roseburg, OR
    i know i need a rearm camber kit. my camber in the rear is hella bad. my car is dropped 2" though. It's bad enough that i can tell the tire is tilted just by glancing at it. I got the front camber kit in, and made the back stand out a lot more. I would suggest a camber kit all the way around with anyone lowering 2" or more.
    CCCC #118 -=-=- VSM #1 -=-=- CCNC #0420
    Banned
    Morgantown, West Virginia
    My car is dropped atleast 2.25" in the rear..and a good 2.5" in the front..and I have NO camber kit in the rear. My camber is perfect in the rear. I do have an inglass kit up front..but the ingalls kits dont fix the camber problem totally.........a camber kit is a MUST if your lowering your car over 1.5"
    Nate.
    Louisiana
    That was My Next Question...
    Yeah I've been doin research at automotive forums and I found some info on the "washer trick". I was wondering if it worked on our cars..
    Here's a quote:
    "The rear camber is corrected by shimming the upper control arms (links) outboard. Add washers between the body and upper mount. Each washer provides 1/2 degree of positive camber. A good rule of thumb is to use one washer per inch that the vehicle is lowered (i.e. if you've lowered your vehicle with an Eibach Pro-Kit (1.5" drop), use 2 washers per bolt for good measure"
    Louisiana
    Here we go...
    Mar 2002
    UT
    Well....thought I already commented on this, guess not lol. I did a 2.5" drop and I still didn't need a rear camber kit. Only thing I can figure is because it's one of two reasons. The camber isn't as offset in the back as in the front from lowering, or the back has more extensive adjustments. I will have to find that out for sure.
    -Aaron-
    Mar 2002
    UT
    Err...dammit, damn browser was seto to work offline so I didn't see any of the new posts. Silly me!
    -Aaron-
