I have an 86 Honda accord lx with a 2bbl keihin carb, auto trans. The carb is a new remanufactured carb and the idle goes up and down. My mechanic said the idle couldn't be adjusted because he thought something was wrong with the throttle cable. Had him change cable and problem is still there. In the morning at cold start the car will start but the fast idle doesn't hold and the car dies. I restart the car and have to hold my foot on the gas and wait for the temperature to go up and then the fast idle will hold at 2500 rpms but will not go down on its own until I tap the gas pedal and then it drops to below normal idle but nothing in between. The other problem I'm having is after the car has been driven awhile I restart it and it goes into fast idle like on a cold start. When the car is warm and been driven I noticed that when I turn on the ac and then turn it off the idle will rise and hang above 1000 rpms and will not come down. I found that if I disconnect the air temperature sensor that's in the snorkel of the air cleaner the idle will drop back to normal. If I restart the car the idle will not go into fast idle either. The air temperature sensor is new. It seems that I only have the idle problems when the air temp sensor is connected. Any ideas of what is wrong.
