Results 1 to 21 of 21
Thread: STP fuel additives ! ?
    Oct 2001
    87 Accord EX , 5spd , Manual
    did anybody used these ! any ups or downs ! i am asking because my father has a problem with fuel on his car !
    thanx a lot !
    MIKE
    carotman's Avatar
    Montreal South Shore
    I used STP Injector Cleaner When I did my EFI conversion and I add a fuel additive each time I take it out of storage.
    I dunno if it actually helps but it helps my peace of mind
    I need these parts!
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I don't really know about those but my dads truck was smoking really bad and he used the STP smoke treatment and that worked. I think STP is a pretty quality brand name. I talked with some dragracers and they said all those bottles that say they boost the octane level, don't work.
    88 LX(x3)87LX(x1)86LXi(x1)
    New Jersey
    mixed feeling..
    i used some smoke treat to soften up my valve seals..seems to have worked, but EVERY time I've put anything but gas in my tank, I neded up changing the fuel pump..since I stopped..I haven;t had a problem. Fuel injector cleaner is mostly kerosene..check the labels
    shepherd79's Avatar
    Falling Waters, WV USA
    i do use all the time. it works for me.
    Oct 2001
    ok thanx guys ! i am gonna put some gas treatment in there ! if it won't help , it won't hurt ! right ! :F
    MIKE
    maka_RTH's Avatar
    Nov 2001
    '95 Supra, '08 CBR 600RR, '89 LX-i Coupe (R.I.P.), '88 LX-i Sedan (R.I.P.), '87 LX-i Sedan (R.I.P.)
    Orem, Utah
    Lucas Oils is also a good one
    Greg
    1989 LX-i 2dr 5spd (R.I.P.)
    Oct 2001
    well i put in today ! we'll see what happens next !
    MIKE
    Mankato, Minnesota
    Hope it goes well for you.
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    Try SeaFoam too, I use that on my Accord, my moped, my lawnmower... lots of stuff
    Oct 2001
    thanx guys !
    MIKE
    Oct 2001
    well after a day of using the car with STP gas treatment ! i am amazed !
    this stuff is really good ! and i thought it was all bullshit ! now i am goin get another bottle for my accord !
    MIKE
    Mankato, Minnesota
    What is it doing (better gas mileage?) I used seafoam and that worked so good that it seemed I had to break in the car another time.
    Oct 2001
    i mean no bad starting or smokin when cold ! didn't check the gas milage yet !
    MIKE
    Mankato, Minnesota
    Man I should get some of that then. It starts bad in this cold weather and smokes kinda bad. What STP bottle did you buy?
    10/Honda/Ridgeline
    NJ
    i have used the Engine restorer that comes in a Tin can kinda. Its was weird cause it was blue shit and really thick. I used this on my gf's 89 corolla gts. her's was drinking up oil like crazy, crazy enough to add a quart every two weeks and its idle was kinda grumpy. THen we went to walmart, got the engine restorer and added it in with the castrol drive hard 10w-30 oil and bang, the engine was quiter, i mean a lot quiter and idles really smooth and did not burn up oil anymore. It also helped to detect oil leak in her oil cooler hose for some reason. and it was good. I really like that product if you ask me, but i never use smoke stop or stp engine treatment or fuel injector clearner. I think i used the gas treatment once, but i did not feel anything. So in my opinion, they are just a big waste of money.
    Mankato, Minnesota
    What was the brand of the engine restorer? Slick 50?
    Oct 2001
    the one i used is STP GAS TREATMENT ! it's pretty cheap too !
    MIKE
    Mankato, Minnesota
    Yeah I might just do that. Mine idles hard. Could just be the cold affecting the weber. i think I might need to get a better fuel pump. I saw the weber ones but they didnt have a price anywhere.
    New Jersey
    slick 50 for me
    when i first got my 87 artic white LX, i dropped some slick 50 into it. When I pulled the head 170k miles later to change the gasket, I could still see the cross hatching in the cylinders..and the engine could have actually passed as a rebuild..no carbon anywhere I could find. Believe it or not. Of course mostly highway driving and not abusing may have contributed to the good news, but in theroy these teflon type addtives do have some merit
    in rgerad to the hard idling issue..maybe check the fuel pump inlet screen for clogging, especially if you didn't have the filler pipe recall done ( look down there with a FLASHLIGHT) to see if there is any rust happening. The rust is so fine it can get thru the filters. I use a giant size filter at the secondary to avod troubles
    10/Honda/Ridgeline
    NJ
    that is what it is. Here is the info on it.
  1. Replies: 0
    Last Post: 03-07-2012, 02:07 PM
  2. dirt fuel tank keeps clogging fuel filters
    By lamontlamont in forum 3geez Accords
    Last Post: 12-12-2005, 10:52 PM
  3. Those additives used on rubber bumpers...
    By offthahook in forum Interior & Exterior Care
    Last Post: 02-05-2003, 09:54 PM
  4. Oil Additives
    By EurAccord in forum 3geez Accords
    Last Post: 12-07-2002, 09:37 AM
  5. fuel and fuel additives
    By Mike's89AccordLX in forum Performance
    Last Post: 10-09-2002, 04:04 PM
