Results 1 to 17 of 17
Thread: C.v joints boot !
    Oct 2001
    87 Accord EX , 5spd , Manual
    C.v joints boot !
    today i was checking my suspension ! and i noticed that my passenger's side outer C.v joint boot is slightly ripped !
    so i said no problem , but when i looked at my haynes , WOW !!! i have to take everything apart even the joints thems selves ! is this true guys ! do you have any other ideas ??
    it's a slight rip ! can i glue it ?
    MIKE
    87 LXi Hatch (5-speed)
    Riverside, CA
    i had the same problem, except the boot was completely ripped. It was fun taking the ball joint off :lol I replaced the whole front axle instead of redoing the cv joint.
    Oct 2001
    well my joint is in good shape ! i don't intend to spend that much of cash now for a new axles !
    MIKE
    Oct 2001
    ok i searched the internet for a while and found out that i can only seperate the puter joint ( after releasing the snap ring in it ! ) then i can remove the boot ! can this be done on our cars ?
    please help guys !
    MIKE
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I remember when my mechanic said my cv boot was ripped. All he did was lube the thing and glued it shut. My CV joints are totally going out. I don't know if I should get a cam or get cv joints. What can go wrong if the cv joint go?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    just alot of noise when turning i think. if u wait along time u will have to replace the whole joint and not just the boot
    SiR's Avatar
    87 Accord LX
    Fort Lauderdale, Florida
    You car wont be going anywhere when that breaks. It'll be like reving in neutral.
    Rooz
    Oct 2001
    ok after after doing more and more research ! i found out the outer C.v joint - driveaxle are one part ! and onlu the inner CV joints can be seperated to change them or change the boot !
    i have just one question ! how to seperate the C.V joint houseing to get to the spider with the rollers !
    MIKE
    Mankato, Minnesota
    Well they have been clicking for 2 years now (now it's just getting bad though) So there's 2 cv joints I would have to buy. (driverside and passenger side) Dam I gotta find some new ones for cheap b/c I don't really want to wait for another group buy for my custom cam.
    89 Accord LX Coupe
    Vernon BC CANADA
    there are some replacement boots that you can get that are split and you must get a glue with it or something....((never used the split ones myself...i always take them apart to clean and re grease))
    just ask the parts store about the cv boots and what they have available...if you buy a split one then you dont have to take the cv off or anything...jsut crawl underneath and your good.
    BEn
    Riverside, CA
    just do the whole axle! it is sooo much simpler than taking the taking apart the cv joint, repacking it, and then hoping you didnt forget anything. It is much quicker and isn't that much more expensive.
    Oct 2001
    well axles cost an arm and a leg around here !
    so a small question !
    it is said in the service manual that you have to adjust the shaft length after installing the boots ! what does that mean ????
    another thing how do you get the DYNAMIC DAMPER off from the right axle MT ( the short one )
    pleeeeeeease guys help !
    MIKE
    Mankato, Minnesota
    I have a friend that installed my brothers cv joints for a $100. So I'll got that route. Didn't take him very long at all either.
    Oct 2001
    i want to do it my self MIKE !
    MIKE
    Oct 2001
    pleeeeeeeeeease help ! here is the queation again !
    " it is said in the service manual that you have to adjust the shaft length after installing the boots ! what does that mean ????
    another thing how do you get the DYNAMIC DAMPER off from the right axle MT ( the short one ) "
    MIKE
    89 Accord LX Coupe
    Vernon BC CANADA
    i looked at my damper and it is held on by a clamp just like the ones on the cv boots...
    and i can twist it so i guess the thing slides off after you take the clamp off!
    as for adjsuting the shaft lenght.....you cant...they move out and in so i wouldnt have a clue to why it would say that in the service manual......
    ive never heard or done that before when ive done cv boots/
    Ben
    Oct 2001
    thanx a lot BEN !
    MIKE
  1. New boot-about
    By CowMan in forum Newbie Introductions
    Last Post: 08-09-2010, 10:23 AM
  2. Split boot for CV joints
    By bluesky6 in forum 1geez Accords
    Last Post: 04-18-2010, 09:38 PM
  3. Converting the boot(y)
    By Kagato in forum Interior & Exterior Care
    Last Post: 09-01-2008, 06:31 PM
  4. Cv Boot??????????
    By Rendon LX-i in forum 3geez Accords
    Last Post: 03-06-2004, 11:27 PM
  5. i think this belongs here, cv boot
    By si accord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-01-2002, 01:50 PM
