Actually I think the damn cops will
. I removed all that vacuum crap and I gotta say this thing kicks. Since I'm no mopar I gotta say this is
my street rod. I've been screeching tires all over the place even when I dont intend to and I cant resist that kick when I punch the gas on the highway. I gotta say this is the most worthwile mod without installing aftermarket parts. Thanks guys for the direction.
Which brings me to one point:
I printed out shepherd79's howto before it went down and I need some clarification at the end about hooking up the vacuum lines. It went something like this (not word for word):
-connect air jet controller line B to port on carb furthest from power valve port along the top.
-connet air jet controller line C to port on carb next to power valve port along the top.
-connect the manifold port to the distributor and power valve port on the carb.
-connect the distributor and intake manifold to the C
Now I had problems with the last line. First I assumed
the C to be from the air jet controller. Second I could get it to run normally even when giving gas without the engine fluttering all over the place. No steady consistent idle and no one way response to the throttle. So I scrapped those connections from the last line and it ran like a champ. Did I miss something or misintepret something on that last line?
BTW, I only capped the choke stuff and float bowl vent rather than remove them. Other than that confusion I had its looking great.
