First off, if it sounds like an internal miss, good possibility that your mixture is to rich.
Let me start off by saying that I had a hell of a time trying to dial in my Kliehn
Carb ( following the initial diagram ). What were you boys thinking? First off, by plugging the main air control jet (front of carb) you need to replace the main jets. The car will run way to rich, miss, deep-exhaust note, smoke, and run like shit.
If you don't want this hastle hook up your air jet controler to the air contol jets (2 slow air control jet(primary & secondary bore) & 1 main air control jet.
**By the way, not all carbed models have a air jet controler (Can. models).
>>>had to remove the one off of my parts car<<<
Car is good on gas, has an excellent bottom to mid-range hit (noticeable improvement)!
But the car runs a little lean on the top-end (no improvement).
Any suggestions??
