Results 1 to 2 of 2
Thread: Idle control solenoid A20A4
    May 2015
    3rd gen Accord 1989 A20A4, 5spd (EX-i)
    Auckland, New Zealand
    So my '89 Accord EX has decided to stop idling recently, and I've troubleshooted it down to a solenoid which can't decide whether it's open or closed (linking inlet to throttle body).
    Unfortunately because in NZ where I live, nobody seems to have these old Accords -- finding OEM parts is incredibly difficult. I've bypassed this solenoid and the engine is running fine (albeit idling at 1100rpm warm), however I know that this isn't the best sort of fix.
    Is it worth even bothering to fix this issue? I'm considering getting a B20 or maybe even H22 swap at some point in the future, and since the engine at least actually runs I guess I'm fine until other issues arrise.
    I've looked on ebay but I don't seem to be using the right terminology to find this part.. I'm happy to upload an image of the part in question.
    Thanks in advance
    DSPhat
    Re: Idle control solenoid A20A4
    try to take if off and clean it with brake clean. Mine had build up inside and once I cleaned and flushed the cooling system it did not have the same idle problem.
  1. idle solenoid diagram?
    By mcl311 in forum 3geez Accords
    Last Post: 11-26-2014, 02:02 PM
  2. Solenoid Control Unit
    By carotman in forum 3geez Accords
    Last Post: 11-04-2008, 02:41 PM
  3. DFAV Idle Solenoid?
    By Doward in forum Carburetor Tech
    Last Post: 11-12-2005, 03:47 PM
  4. A/C Idle Boost Solenoid Valve
    By AccordAddict in forum 3geez Accords
    Last Post: 08-23-2004, 12:10 AM
  5. idle boost solenoid
    By seancornelis in forum Carburetor Tech
    Last Post: 10-22-2003, 08:31 PM
