Recently my car has been loosing oil I think it may be leaking from the pan but can't be sure. It seems like its at a good level everytime a check it but every once in a while I check it and its a tad below low.. Today I drove about 50 miles and then 50 miles back without any problems I get back home turn the car off for about 2 hours I drive about a mile and my needle shoots all the way up. Open the hood touched my radiator and it was cool so I open it up and coolant spews up because it was so hot, I had to put about a gallon of water in and check my oil.. a tad below low add a quart and drive it about 4 more miles and back home and its fine checked my oil level its almost topped off and the coolant is good...
I've noticed no degraded performance, no water in the oil or vise versa and no overheating besides tonight when I lost all that coolant.. but I did look at my oil pan and noticed antifreeze dripping from the bottom of it and around that area but I also saw my hood underneath had a strip of antifreeze from the place where the hood holder goes all the way down about 3 inches wide and as long as the hood underneath but there aren't any coolant lines running there and there isn't any antifreeze anywhere else.. on another note my belts have been squeeling alot latley I kept spraying belt dressing on them and it seemed to make it worse I left them alone for a couple days, it still does it but not as often the belts seem to be tight enough.
Any ideas where my oil could be going and why I could of lost so much coolant in such a weird place..
