I got a new main relay to replace one that I suspect is bad. Unfortunately I am nowhere even close to being able to get the old one out.
Method tried... result:
1. Using a flat head to pull the innards out of the mounted casing... i can only get one hand in at a time and am unable to free the innards.
2. Using a ratchet to remove the mounting bolt... can't connect the ratchet due to the connecting wires in the way
3. Removing the connecting wires... can only get my fingertips (no thumb) on the connection, unable to disconnect
4. Removing the cruise control brain... disconnected one bolt, but it still seems to be attached and i can't see any other bolts to free it.
5. Removing the underside of the dash... found two bolts to remove it, but it still seems pretty solidly connected to the upper dash and I can't see how.
This is really pissing me off. People talk about fixing or replacing their main relay here and mention it's tough to get to, but somehow they always get it out. I have normal sized hands, but there is absolutely no way getting this thing out is possible with the space I am working with.
