Results 1 to 6 of 6
Thread: 88 Accord DX 5speed Axel from spindle removel
    Mar 2016
    1988 Honda Accord DX
    Chattanooga
    I' ve been trying to remove my knuckle from the axle on the drivers side to no avail. I've rented a slide hammer and worked on it for hours...nothing. Anyone know of a trick or easy method to get this removed? Trying to replace the wheel bearing. Thanks in advance. new2medx
    Mar 2012
    1988 Honda Accord LX-i 2 Door Coupe 5 Speed
    Charlotte, NC
    Re: 88 Accord DX 5speed Axel from spindle removel
    Are you trying to remove the cv axle or the hub from the knuckle. I'm going to assume you did take the axle nut off the end right? You have to separate the lower ball joint from the knuckle to get enough clearance to get the axle out. Damper fork also has to be removed from the LCA and the strut.
    Mar 2012
    Charlotte, NC
    If the CV axle won't come out of the spindle, that would be something I've never heard of or seen. Only advice would be find the biggest sledge hammer you can find and hit the end of the axle stub as hard as you can (leave axle nut just flush to protect threads)
    Quote Originally Posted by new2medx View Post
    you might have to use some kinda of puller to get the bearing end off.
    A large 3 jaw puller should do it.
    Other option it take axel and all off the car and have them pressed apart at a shop.
    Mar 2016
    Chattanooga
    Thanks all, the puller did the job.
    Yeah sometimes brute force is NOT the answer just slow steady pressure.
    Learned that the hard way to many times to tell on here.
  1. vaccum removel.
    By danny nr crew in forum Classic Honda Pics & Videos
    Last Post: 07-27-2011, 03:07 PM
  2. 1989 Accord Engine Extraction CV axel wisdom...
    By parkersnine in forum 3geez Accords
    Last Post: 07-02-2009, 03:15 AM
  3. performance parts for a 89 accord dx carb A20A1 5Speed
    By josephgilpin in forum Performance
    Last Post: 11-16-2006, 09:34 AM
  4. Does your 5speed 86-89 accord start without pushing the clutch in???????
    By Vinny in forum Classic Honda Community Chat
    Last Post: 07-31-2005, 12:25 AM
  5. Climate Control Removel???
    By Rendon LX-i in forum 3geez Accords
    Last Post: 07-25-2005, 08:54 PM
