Hi 3geez,
I bought a 3rd gen accord with a blown head gasket. I pulled the engine, took off the head and sent it to a machine shop. When I got a new gasket and put the head back on after I get it back, I noticed the machine shop had adjusted the camshaft. I decided to go ahead and replace the timing belt, but I could not find a timing mark anywhere besides the flywheel (couldn't find the spot on the block where the lines are to match it, though). So, I took some weed-eater string and felt out piston #1 to feel for TDC; however, it seems there are a few degrees when turning the crankshaft that it stays at the very top. So my concern is, even though I have the block at top dead center, and the camshaft lines lined up on the head, how do I know that it isn't off a tooth? What do you guys think? I'm quite concerned about starting it for the first time as I don't want to risk damage.
